RV.Net Open Roads Forum: AC Quits Blowing Cold after a few minutes
 > AC Quits Blowing Cold after a few minutes
adventureman5
la center
Posted: 05/01/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
My AC Won't keep blowing cold on my 2006 RV E-450 gas. I just replaced the
high and low cut-off switches and when I put the pressure gauge on the AC, it
said that everything was running perfect and it was running cold too. But then
let it run for ten minutes and it stops blowing cold and now the pressure gauge
reads above the high area into the yellow and headed towards red (too much
pressure) and I can no longer hear the compressor kicking on and off. I actually
let out some of the freon, since the gauge now read too high. But this has
been a cat and mouse game for some time. We changed out the relays and
that didn't help. It's blowing fine, there doesn't appear to be any vacuum
leaks, as I've read about those (and it was running fine going up hills prior to
this). Right now it's just sitting flat on my property and not even working the
engine. No blockages. But it makes travel in summer months pretty awful. Any
ideas?
Posted: 05/01/22 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
If I had to take a guess. and given your post all I can do is guess.
You need to clean the condenser coil.. On other than coleman this involves some work... First remove the outer cowl (Cover) on the A/C.. Generally this is about a dozen phillips head screws around the bottom (A magnetic parts tray is nice to keep track of 'em (Harbor freight, most auto stores, many hardware). Then you need to remove the INNER cover over the condenser.. This can be easy (A few more screws) or major (Cut the sealing tape. Unbend the tabs and so on) now you can see the crud blocking the thing.. You may need to pull the condenser fan (I did but I wear an xxl or xxxl glove) or use a soft brush to coax the crud off the fins...
Then you get to put it all back together.
Coleman instruction
Remove 4 bolts (Philips head) from the top of the unit and lift off cowl
Peal the condenser clean, replace cowl, replace bolts.
adventureman5
la center
Posted: 05/01/22 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick reply. Okay, if I didn't make myself clear, let me start again. This is the Chassis AC - the one installed by the Ford Chassis, not the roof mounted coach one. So this is the AC blowing out of the dash while you drive down the road.
Gdetrailer
PA
Posted: 05/01/22 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
backup a bit.
You may have a worn compressor clutch creating too large of a air gap which often will engage for a short time then will disengage as the pressure in the system increases from heat.
Verify that the compressor is staying engaged with the clutch, if the center part of the pulley stops spinning you have a worn clutch.
Sometimes the center part of the pulley will still be spinning, but not as fast as it should and that is also a sign of worn clutch.
To find out for sure, you will want to verify the clutch air gap. This is done with feeler gauges..
Sometimes the air gap can be restored by changing/adding/removing shims.
SEE HERE
Found a good video on how to check the air gap, remove the clutch and how to adjust the gap..
HERE
Make sure the air gap is correct before trying other stuff..
time2roll
Posted: 05/01/22 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
My guess would be the expansion valve needs to be replaced. Probably should replace the receiver/drier also.
675w Solar pictures back up
ernie1
Sacramento,California,USA
Posted: 05/01/22 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
What are the pressures both low and high while it is cooling and what are they when they start going up and quits cooling? I'll venture a guess and say that the unit was low on gas and someone added some or too much and also did not do it properly and introduced some air into the system. Air in the system will cause what you're reporting.
Also I don't think a dirty evaporator( someone called it a condenser) will cause this problem.
What gas does your ac system use? Are you refilling with the sam? Maybe R134A?
I doubt that the clutch is the problem.
adventureman5
la center
Posted: 05/01/22 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! Lots of ideas. Let me see what I can answer before I go check some more things to help answer....
Yes, using the same gas. R134A.
I'm pretty sure I did overfill it the first time. I assumed, probably wrongly, that it was low. Bought the gas and it said low, so I put in what the guy at Autozone told me to expect to put in. When it started kicking in the clutch, it shot up way too high. Now I had to let a whole bunch out and there is no good way to do that except to waste it while sitting in the parking lot....
Today pressure reading was spot on, until the clutch quit kicking on and off after I replace the high and low pressure valves.
I'll look at the pulley tomorrow....
lryrob9301
Anywhere
Posted: 05/01/22 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
This is the correct answer. Also make SURE you are not overcharging the unit, refill with the correct amount of R134 as per the manufacturer's instructions.
Gdetrailer
PA
Posted: 05/02/22 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I suspect that the clutch was the original problem. Clutch slippage is more common than one might think. Checking the air gap is very easy and quick to do.
When the air gap gets on the outer edge of the specs it can randomly engage or disengage without any warning or reason.
Often engaging initially when engine is cold then drive a couple of miles and no more cool air when the gap is just past specs. Reving the engine doesn't reengage, going faster doesn't help but often you can "bump" the center of the pulley and you now get cold air until the electric to the clutch is removed and you have to bump it again.
Have ran into that myself with a '03 Ford..
OP most likely added a new problem by adding refrigerant when it wasn't really needed (to much air gap mimics the same symptom as too low on refrigerant)which leads to overfilling.
S Davis
Western WA
Posted: 05/02/22 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Be careful venting refrigerant, you can get a hefty fine.
