RV.Net Open Roads Forum: General RVing Issues: first commercially available all electric RV
 > first commercially available all electric RV
pianotuna
Regina, SK, Canada
Posted: 05/02/22 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
https://camperreport.com/fully-electric-rv/
About $79,000 usd.
* This post was edited 05/02/22 01:52pm by pianotuna *
Regards, Don
Southern California :(
Posted: 05/02/22 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Another interesting step forward. TY for posting.
valhalla360
No paticular place.
Posted: 05/02/22 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
That's pretty pricey when your average 20ft trailer is going for around $20k USD (I'm sure they will claim it's all super high end)
Still need to be judicious with 7kwh battery pack and 2kwh daily generation.
Also, I looked on the company's site and couldn't find any info on heating?
Seems like if you are geared specifically to an all electric rig, they would clearly layout the electrical devices and generation info.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Posted: 05/02/22 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Amazing what can be done when it is part of the original design.
Our modified RV trailers pale in comparison.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 05/02/22 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
I thought it was self propelled. mea culpa.
It uses a heat pump for cooling and heating. It includes a washer and drier.
valhalla360
No paticular place.
Posted: 05/02/22 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Still would have been a bit pricey but at least it would have been something new to actually have one for sale.
mockturtle
AZ
Posted: 05/02/22 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
It's a trailer.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Skibane
San Antonio, TX
Posted: 05/02/22 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Perhaps I missed it, but didn't see any mention of how they heat or cool it.
14.3 KWH of battery energy is just slightly under 50K BTU - Enough to run a 12K BTU air conditioner for around 4 hours a day (assuming perfect efficiency, 100% battery discharge, and no other electrical loads being used).
I assume they would use some sort of heat pump for heating, since resistance electric heat is very energy-inefficient.
Typically, you get less sunlight in cold climates and during cold seasons - so there would often be less solar panel output available for heating. On rainy or completely overcast days, you either make do with whatever's still in the battery, or do without.
way2roll
Wilmington NC
Posted: 05/02/22 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Mentioned an under the bed AC unit and detailed about the insulation that helps keeps things cooler (or warmer).
Y-Guy
Tri-Cities, WA
Posted: 05/02/22 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Tech Issues to General RVing Issues.
