RV.Net Open Roads Forum: Technology Corner: RV's and internet connections
 > RV's and internet connections
venice fl
Posted: 05/02/22 11:16am Link  |  Quote  |  Print  |  Notify Moderator
We are new to RV'ing. Apparently there is not good internet for TV viewing when camping. We have 1 smart TV & 2 regular TV's. I was told to purchase 2 Roku's for the non-smart TV's. We have Xfinity for home internet, TV, and cell phones. I am reading that using your phone as a hot spot does not give you enough band width. Any recommendations out there? Do I need a separate hotspot device that I have to pay for and add that to my Xfinity plan?
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 05/02/22 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Technology for more responses
Admin
RV.net
2oldman
NM
Posted: 05/02/22 11:38am Link  |  Quote  |  Print  |  Notify Moderator
My phone's hotspot does just fine. Eats data like crazy though.
Southern California :(
Posted: 05/02/22 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forum! I frequently camp in boondocking areas where using my iPad or iPhone for TV watching works just fine. Depends are where you are camping.
theoldwizard1
SE MI
Posted: 05/02/22 11:48am Link  |  Quote  |  Print  |  Notify Moderator
The only advantage some dedicated hot spot devices have is a connection for an external antenna.
Read the "fine print" on your cell phone contract. Most will slow you down after a certain amount of data is used. At the slower speed watching TV is an issue.
Posted: 05/02/22 11:50am Link  |  Quote  |  Print  |  Notify Moderator
I also have success frequently with over the air (OTA) channels for local news.
pianotuna
Regina, SK, Canada
Posted: 05/02/22 11:58am Link  |  Quote  |  Print  |  Notify Moderator
My cell phone gets throttled after 25 gigs of data. When it is, the speed drops to 2 megs/second. I find that is enough to watch netflix. I do watch on a laptop.
Regards, Don
1492
Arlington, VA
Posted: 05/02/22 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Most 4G mobile data can stream channels with no problem. The issue is whether your mobile plan has enough monthly 'high-speed' bandwidth allowance sufficient for your viewing needs.
valhalla360
No paticular place.
Posted: 05/02/22 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Might struggle if you want 4k quality but the technology can generally handle it. Even old 3G networks can work.
The problem as mentioned getting a plan that gives you enough data without throttling.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
2oldman
NM
Posted: 05/02/22 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have that, the old XXL Verizon plan. 28G a month, with carryover, and no throttling. Last I looked I had around 55G, which is pretty good for watching Breaking Bad and Japanese cats.
I'm not sure if there's an upper limit to what you can carry over.
