RV.Net Open Roads Forum: Travel Trailers: Spare tire pressure
 > Spare tire pressure
Skipg
Yuma
Posted: 05/04/22 10:31am Link  |  Quote  |  Print  |  Notify Moderator
The four tires on my travel trailer specify 80 pounds each tire the spare tire only is rated for 65 pounds is this correct?
Near Bishop, California
Posted: 05/04/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
I keep my two spare TT tires at their max rated pressure…ready to go.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Microlite Mike
NW Washington State
Posted: 05/04/22 10:46am Link  |  Quote  |  Print  |  Notify Moderator
The tires on the ground are likely Load Range E which has a max inflation pressure of 80 psi. The Spare is a Load Range D which has a max inflation pressure of 65 psi.
Somewhere along the line the tires on the ground have been upgraded from the OE tires but spare was not.
I would NOT inflate the spare to 80 psi if you ever have to use it.
I would check the sticker on the side of your trailer (usually on the left side,
front corner) and see what tires were OE and the pressure specified. If it specifies 80 psi I'd replace the spare with a Load Range E so if you DO have to use it, you won't be running on an under-rated tire.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
bgum
South Louisiana
Posted: 05/04/22 10:51am Link  |  Quote  |  Print  |  Notify Moderator
If you say so yes. Clearly something is up. Are they the original tires? If not someone upgraded the tires on the ground or downgraded the spare.
Posted: 05/04/22 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Depends what your trailer weighs.
Likely scenario, OE tires 65psi, hence the spare. Tires on trailer upgraded to heavier load rating when replaced.
The real question is do you need 80psi in your 80psi max tires or are they overinflated for the job they’re doing.
(With few exceptions, like the “.5s” , 17.5, 19.5, 22.5 tires, most all passenger vehicle and ST tires are fine to be used at the proper pressure even if rated higher. Side benefit, stronger, longer lasting tires)
2017 Heartland Torque T29
Something is up? Lol.
This isn’t a murder mystery!
Skipg
Yuma
Posted: 05/04/22 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Yes they are all original tires on a new not used travel trailer.
bgum
South Louisiana
Posted: 05/04/22 11:31am Link  |  Quote  |  Print  |  Notify Moderator
I would confront dealer with your information and ask for a matching tire and rim.
Posted: 05/04/22 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Do you know what tires it’s supposed to come with? Do you know it’s an issue?
Did you pay extra for a spare and got a lesser tire, or did you somehow get a bonus and get upgraded tires from standard spec for the trailer?
Or you could just do as another member suggested and blindly call the dealer and complain.
But I usually like to be able to speak with a decent level of knowledge before I start claiming I was wronged…
Posted: 05/04/22 11:39am Link  |  Quote  |  Print  |  Notify Moderator
X2
