thomasmnile
Lake Mary, FL
Sounds like an Amish craftsman goofed up.......
Skipg wrote: I would like to think that it was a mistake and not a common practice
Is there a reason you don’t answer questions that providing the information for would help you better understand what your actual needs are? Especially considering your first post was asking for help understanding what your actual needs are?
There are vehicles that don’t come with the same spare tire as the ones on the ground. For various reasons of course. Not saying this is the case for sure in your case. But since you don’t provide any specific info asked (asked to help you answer your initial question of course), I can reasonably surmise based on what little info you provided that it’s a TT. And it’s a 15” wheel. And the gvw of your TT is probably 10-11klbs or less and that a D rated 15” ST tire would likely be of sufficient capacity based on the numbers. (Numbers which would not require supposition but if not for ^)
RCMAN46
NorthWest
My trailer and TV have TPMS. I added a TPMS sensor on the trailer spare and the TV spare.
As mentioned it is easy to overlook the spare tire. This way I will be warned if either spare is low on pressure.
RCMAN46 wrote: My trailer and TV have TPMS. I added a TPMS sensor on the trailer spare and the TV spare.
Ok??
Relevance to rating on spare tire vs other tires on the vehicle?
dave54
Northeast CA.
JRscooby wrote: Off topic, but kind of related; Spare tire on TV. Most people at least look at tires on the ground every day but often do not check the spare. I always air my spare up to max sidewall on the theory it is more likely to have enough when I need it. Yes, I have a compressor, can air up spare. But it is quicker to reduce pressure and over inflated is safer than under inflated.
SOP with me.
After every trip I crawl underneath with a mechanics mirror and flashlight, looking for anything amiss (stick or branch wedged up somewhere, chunk of mud, loose nuts, wear spot on wiring or piping, etc. Check pressure while under there. A cheap Walmart yoga mat saves your clothes and back from the inevitable thorns and sharp rocks on the ground.
I also do not wait until the day of departure from a campsite to check underneath. I check it the first morning there. Then I have several days to fix any problem rather than have my itinerary delayed from a problem discovered on day of departure.
So many campsites, so little time...
deltabravo
Spokane, WA
I'd make the dealer solve the problem and let them deal with getting reimbursed from the manufacturer.
