RV.Net Open Roads Forum: Tech Issues: onan marquis 7000 generator /no start
 > onan marquis 7000 generator /no start
Stickkman99
va
Posted: 05/06/22 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
the pump for the generator only dribbeled.......the inline pump i put on it flowed good but it still would not start unless i kept the choke closed....
Stickkman99
va
Posted: 05/06/22 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
i think the pump it is bad although it runs just no pressure.....maybe the carb is stopped up also since it would not run with the inline pump...??
Gjac
Milford, CT
Posted: 05/08/22 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know what kind of choke you have but mine is a Bi-metal spring that opens up once the engine warms up. What kind of a choke do you have? Try adjusting or resetting the choke to where it starts. From your description it only starts when the choke is closed or on. From there it should open as the engine warms up. How old is your genset?
Gary45
Oshawa, Ontario, Canada
Posted: 05/08/22 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Main jet is plugged, it screws into the bottom of the fuel bowl, usually just unscrew clean and replace.
Stickkman99
va
Posted: 05/09/22 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
ok....got the generator running........main jet was clogged.....everything running good.....now to change the oil and filter...i dont have a manual....so what oil should i use??
Gary45
Posted: 05/10/22 06:33am Link  |  Quote  |  Print  |  Notify Moderator
15 - 40 any brand
Kpackpackkelley
Bryan tx
Posted: 05/10/22 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Gary45 wrote:
15 - 40 any brand
Good info.
RLS7201
Posted: 05/10/22 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Air cooled engines run hotter than water cooled engines. Thus the manufacture does not recommend multi viscosity oils. BUT! that ruling was for non-synthetic oil. Standard oils loose their multi viscosity capacity when run to hot and thin out. So when running multi viscosity oils in air cooled engines, always use synthetic oil. I have the same generator as you and have used 10W-30 synthetic for 22 years with no problems.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Gary45
Posted: 05/10/22 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Richard
Regular multi viscosity oil is fine in an air cooled motor, air cooled motors do not have a thermostat to make them run as hot as water cooled motors. There are no air cooled car or motorcycle engines anymore because they cannot get them to run hot enough for modern fuel injection pollution control systems.
joebedford
Sheltering at home
Posted: 05/10/22 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Uhhhh, Harley? Some are liquid cooled but most are not.
