DD716TED
Washington State
My trailer is stored a small distance from the house. In view of ever increasing theft / vandalism, I installed a wifi camera near it. 50 % of the time, the camera works great and I can see / record anything going on...BUT the other 50% of the time, the camera looses wifi connection... would installing a wifi extender half way between the router and camera work or are wifi range extenders a waste of time and $$$? Appreciate any comments..as crime is on rise
2oldman
NM
I have a CC Vector antenna, but that's probably more than you want to spend. It works great from hundreds of feet away.
bgum
South Louisiana
Yes wifi extenders work. What you propose to do will help.
BurbMan
Indianapolis, IN
I have my office in a detached building from the main house and use a Google Nest and it really extends the distance. use the main one in place of your current router then add the other two in place around the house. Place one at the closest indoor point that you can to the camera.
My cable enters the house on the opposite side from where the office is, so I put one in the house about halfway and the other out here in the office and the signal is great.
Near Mammoth, California
I use an extender to get good WiFi in my detached garage. Works just great.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
TenOC
On the road -- Full time
Works well for me and low price
TP-Link Long Range Outdoor Wifi Transmitter from Amazon $37.00 (?)
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Ubiquiti I used a Nano Station Loco M but they make even better ones.
Not sure of the spelling but that should be close enough for Google.
DD716TED
Washington State
Thanks for inputs.. I used an inexpensive wifi extender and now all works great..
pinesman
virginia
Not to hijack the thread, but has anyone had any luck with the wifi extenders working through a metal sided building?
Fisherman
Angus, Ontario, Canada
pinesman wrote: Not to hijack the thread, but has anyone had any luck with the wifi extenders working through a metal sided building?
Anything that has metal, such as metal blinds, doors, furniture, infrastructure, and walls, can greatly diminish or completely terminate the WiFi signal. The more metal there is between your WiFi router and the connected device, the worse the WiFi signal will be.Oct 22, 2020
