RV.Net Open Roads Forum: Tech Issues: Replacement City Water Inlet recommendation
 > Replacement City Water Inlet recommendation
Missionstreet
PA
Posted: 05/05/22 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
Well, the original inlet city water connection on my rig has been leaking at the GHT connection so I'm looking to replace it. It's also a pain to tighten.
I've seen alot of 1 star reviews for bad quality/faulty parts, can anyone recommend a good brand to buy? I've got a female NPT end on mine. I'm guessing all metal maybe.
Thanks
bucky
Raleigh metro
Posted: 05/06/22 04:20am Link  |  Quote  |  Print  |  Notify Moderator
I had the same issue. I bought and installed a
Valterra A01-2000VP Gravity/City Water Inlet Hatch. It seemed to be the same price everywhere online, $52. This is the model with the door, the model without the door is a different size and doesn't interchange.
Hopefully the back of yours is as easy to get to as ours was.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
jdc1
Rescue, Ca
Posted: 05/06/22 07:07am Link  |  Quote  |  Print  |  Notify Moderator
You have to take caution when ordering the new assembly. There are more than one size, with or without the door. I have read in the past that the few that have the plastic hose connectors do not leak over time vs those that are made of metal. So, I used that one in replacing mine a few months ago. It works fine, but is not time tested. Oh, as a footnote, they are not easy to replace. The filler and overflow hoses are cut just long enough to frustrate re-assembly. Hopefully you have other access door close to the newly installed assembly you can reach through, like an outside shower. I had to remove the outside shower box and use that access to reach in and connect the two hoses mentioned.
Bobbo
Wherever I park
Posted: 05/06/22 07:20am Link  |  Quote  |  Print  |  Notify Moderator
If it is only leaking at the GHT connection, I would first try a new washer in it. Get a real rubber washer, not one of the neoprene types.
Bobbo and Lin
agesilaus
North Florida
Posted: 05/06/22 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Well how timely, I just broke my old plastic one and replaced it with this
Or I should say will replace it this morning, I have the new one sitting on my desk. I is all metal and distinctly heavier than the broken one. The pipe is brass.
You need to be careful screwing a metal fitting into a PVC one, the female piping is PVC on my TT. It is easy to cross thread when doing it.The heavy regulator was the culprit in the death of the old fitting.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
2oldman
NM
Posted: 05/06/22 07:58am Link  |  Quote  |  Print  |  Notify Moderator
You mean it's leaking when you use it, or it's leaking when using your pump?
opnspaces
San Diego Ca
Posted: 05/06/22 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced mine with this one. I liked that it has a metal flange vs the plastic flange on the Camco. I've only tested it once and it worked fine. I'm heading out in a few hours for a weekend trip so I'll post back it I have any troubles.
Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Dusty R
Charlotte Michigan 48813
Posted: 05/06/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I have some O-ring type hose gaskets, they work nice.
2oldman
NM
Posted: 05/07/22 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
he's gone
Missionstreet
PA
Posted: 05/08/22 02:34am Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the late reply crazy weekend wow you all are great this is amazing response.
It's leaking when pump is on and when trying to connect so I figure I might as well replace the whole assembly (the check valve to the best of my knowledge seems to be part of this one).
I've considered the Valterra (flush mount without the door) but it appears to have some complaints like the others. What's the OEM maker of this stuff? Do they have premature and D.O.A. failure complaints as well? Lol.
