RV.Net Open Roads Forum: Tech Issues: Replacement City Water Inlet recommendation
 > Replacement City Water Inlet recommendation
2oldman
NM
Posted: 05/08/22 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Missionstreet wrote:
It's leaking when pump is on and when trying to connect
I just put a plug in mine. I never hook up the hose.
opnspaces
San Diego Ca
Posted: 05/08/22 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
I ran a plug in mine for a while actually two different plugs and it never wanted to seal very well. eventually I just replaced the whole unit.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
bucky
Raleigh metro
Posted: 05/09/22 03:34am Link  |  Quote  |  Print  |  Notify Moderator
The city water connection on both of the Valterra units I mentioned is brass. Only the fresh and it's sister overflow connections are plastic.
I had to pull the sofa away from the back wall and take apart one of the armrests for access.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
travelRVforever
Michigan
Posted: 08/10/22 09:57am Link  |  Quote  |  Print  |  Notify Moderator
ValterraParts.com has tones of information on all their parts with videos explaining how the parts work and which model is best depending on your situation.
stevenal
Newport, OR, USA
Posted: 08/10/22 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I’m confused. Why run the pump when on city water?
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
