RV.Net Open Roads Forum: Truck Campers: Cabover clearance w/new truck?
 > Cabover clearance w/new truck?
Daryl_B
Michigan
Posted: 05/06/22 06:48am Link  |  Quote  |  Print  |  Notify Moderator
In the past I've had a few truck campers, (2) AF 990 and an EC 1165 that I hauled on a 2006 F-450. I never had any cab clearance issues with any of them just using just a 3/8" standard bed mat on top of a spray in bed liner.
My new truck is a 2022 F-450 with Line-X bed liner. I have the TorkLift tie downs installed and have been keeping an eye out for a used truck camper. I recently located a 2019 AF 1140 and am planning a trip (12hr drive each way) to go pick it up next weekend. I was thinking of getting the 3/4" thick rubber horse mats.
Does anyone have any experience with hauling an Arctic Fox in a newer Ford truck? How much cabover clearance is there? Will a 3/4" thick mat be enough?
2022 F-450
2019 Arctic Fox 1140 WB
Past Rigs
2006 F-450 16k GVWR, Kelderman 4-link rear suspension
2009 AF 990
2016 EC 1165
2017 AF 990
deltabravo
Spokane, WA
Posted: 05/06/22 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Occasionally the sharkfin antenna of Ford trucks has poked a hole in the underside of the cabover of an Arctic Fox truck due to lack of clearance.
3/4" should be good, but you might consider checking out this group
Daryl_B
Michigan
Posted: 05/06/22 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link, I'll see if anyone on that group has any input
Ford did away with the shark fin antenna, my truck has (2) lower profile antenna's, 1 on each corner at the rear of the cab.
BurbMan
Indianapolis, IN
Posted: 05/06/22 07:22am Link  |  Quote  |  Print  |  Notify Moderator
You might call ahead and ask the seller to measure from the bottom of the camper to the bottom of the cabover, then you can measure from bed floor to cab roof and compare numbers. I used a pair of 2x10's in the bed and that gave me about 1" over the shark fin on the truck and never had an issue. It was handy because when I took the camper off the truck, I used those same planks on top of cement blocks to store the camper.
tcguy
SW Ohio
Posted: 05/06/22 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I've got a 2020 AF990 camper on a 2018 F350 CC dually with only a 3/8 bed mat and have plenty of clearance. Have traveled thousands of miles on all types of roads without any issues.
deltabravo
Spokane, WA
Posted: 05/06/22 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
That's good news. I saw a Ford the other day with two bumps near the CHMSL and wondered if they were new style antennas.
Daryl_B
Michigan
Posted: 05/24/22 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Update - We drove out to Vermont on 5/13 to finalize the purchase of a 2019 AF 1140. Everything went as planned. I had installed (1) layer of 3/4" stall mats and a 3/8" thick bed mat that I had from another truck on top of the stall mats. I ended up having plenty of cab over clearance.
Bedlam
PNW
Posted: 05/24/22 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
If I remember correctly, the Arctic Fox has 4' between the underside of the cab over and the basement floor.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
