pasusan
Northernmost PA
I'm still new to this anode rod business as we've always had an Atwood water heater...
So tell me - is this normal and should it be replaced now?
![[image]](https://i.imgur.com/GN8fV1yl.jpg)
We're afraid that it will keep getting thinner at that one spot and then fall off in the water heater. Is that possible?
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
wildtoad
Blythewood, SC
Never had one break. Yours looks quite normal and has plenty of life left in it. Your manual states to drain the tank when not in use (for a while). This will extend the life of the anode rod.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Roger10378
Goodrich, MI.
There is not much chance of it breaking off,there is a steel rod running thru the middle. This one is just starting to show some usage.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
way2roll
Wilmington NC
When your hot water starts to smell like rotten eggs, it's time to change it. I keep spares in my RV. I find they last about a year but it really depends on the water.
2023 FR Sunseeker 2400B MBS
2112
As Roger said, there is a wire coat hanger size rod in the center holding it to the cap. I replace mine when the only thing left is the rod.
You have a long way to go to get there
2013 KZ Durango 2857
StirCrazy
Kamloops, BC, Canada
when I pull mine for winter prep, if they are worn to about 1/2 the diamiter I change them. when I lived on the island that was about every year or two up here we have better city water, so its every 3 to 4 years.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
joelc
Cedar Point, NC
By you picture. Not yet. It is working. The water attacks your anode rod instead of the hot water tank. I check mine every 6 months as a full timer. In some areas the water is more corrosive than in others, so if you travel check it often. You don't want holes in your tank. Be sure to have a spare one, so you can change it if needed. Be sure to get the right one. There are 2 different metals the rod is made of. I have a Suburban so mine might be different than yours. If you know which one you need....great. If not look it up on the internet using your brand name and model on the internet.
pasusan
Northernmost PA
Thanks to everyone for the replies.
We do drain it when not using and we use a magnesium rod. I learned those things here - we used to have an aluminum rod and it never wore out.
So - we won't worry that it will break off in the water heater - very good to know!
dodge guy
Bartlett IL
Depending on use you can get 3-4 years out of one. Only once did I ever get a year out of one! That still has at least one probably 2 years left I it. Once you get near the metal rod (1/8” rod) then it’s time to replace it.
You want to be really shocked? Flush it out with a water hose with an attachment that has a stream. I just flushed mine and got a ton of crud out of it!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Cummins12V98
on the road
Your anode is perfectly fine!!! Re install it and check once a year. Mine is at least 6 years and and looks basically like yours.
Get a small tube to flush out the tank every time. Don't forget to turn off the power before draining your tank.
Anode deterioration is all about the quality of water. I am mostly west Coast and the water is awesome!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
