2112
THIS is for a 2016 trailer running light fuse but will give you an idea of where to look.
I think what you are looking for is Fuse 60 in the smaller front fuse/relay box under the hood. Should be 15A
last
edited 05/07/22 10:05pm by 2112 *
View edit history
2013 KZ Durango 2857
JaxDad
Greater Toronto Area
I can’t believe in all of this nobody suggested plugging a $5 tester into the TV’s trailer lug to see if the issue is TV or trailer.
That’s the FIRST place to start, not the last.
Buckaroo Billy
Fenton,MO.
Looked through the ATO fuses in the small fuse box under the hood, located a 15ATO that was labeled "Tail/Turn" that was blown.
I'll pick some fuses up on my way home tomorrow, put one in and see what results.
BarabooBob
Baraboo, WI
While you are picking up fuses, pick up an assortment of the proper fuse type for your truck. I have given away more fuses over the years to people that did not have any with them than I have replaced in my rig.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
enblethen
Moses Lake, WA
Look at the fuses in the 12 volt DC section of your rig. Get spare fuses for it.
I would not buy a box of various sizes (amperage) of fuses. I would get boxes of amperage that your rig uses.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MitchF150
Puyallup, WA
Quote: It was busted, got rear ended some time ago and Hitch took the brunt but snapped the plastic housing for the 7-way just enough it would just teeter when you hooked up the plug.
Yeah, something must have shorted out with the accident that damaged the connector. The hitch itself could be damaged too? Have you had that checked out too?
Mitch
Buckaroo Billy
Fenton,MO.
Looked under the hood at the small fuse box.
a 15amp blown, labeled "Trail/Turn" just got home and replaced it.
"Eureka" !! that fixed it. got signal lights, regular lights, turn signals and brake lights!!
Thanks all for your assistance!
All the Best!!
Side Bar: 2112 Thanks for the video, It wasn't in the Big fuse box it was in the smaller box to the right. But it works now.
edited 05/09/22 07:25pm by Buckaroo Billy *
2112
Quote: Side Bar: 2112 Thanks for the video, It wasn't in the Big fuse box it was in the smaller box to the right. But it works now
Happy to help.
Thanks for letting us know you solved the problem
