Bobmontana
Montana
While towing our 3000lb travel trailer with our 2011 Yukon xl 1500 5.3 litre I found that it does ok for the most part but the transmission did get up to 220 degrees going over Macdonald pass in Montana. We were down to 45mph and 3000 rpm just as we crested over and the trans gauge touched 220. Has anyone replaced the stock cooler with a larger one that is a OEM ? I don't like the idea of scabbing in a cooler attatched too the radiator and just rubber hose clamped to the lines. Than you for your time.
Turtle n Peeps
California
220 for modern ATF synthetics is not hot at all. Warm, but not hot.
The warning chime for my truck comes on around 265 or 270?
You can put another cooler on as you have said but there really is no reason too. The problem also it if you do cool off the tranny then those BTU's will go into the engine coolant stack and that can cause problems too.
Not saying to not put another ATF cooler in the stack, I'm just telling you some of the drawbacks because very few on this site seems to want to talk about those.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Near Bishop, California
220F is the upper limit but not excessive IMO when going up a grade with a trailer.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MitchF150
Puyallup, WA
As long as it cools down again when you are not working it hard, then your current cooler is doing it's job.
Your trans probably has an internal thermostat on it anyway.. So, it'll only cool down so much anyway.. Probably around *190-195 range.
If you do decide to get more cooling for the trans, don't add a second cooler... Get a bigger cooler than OEM and leave it all plumbed the same way.
Good luck! Mitch
Roger10378
Goodrich, MI.
I like to see trans temperature reach 220 occasionally. Water condenses in the trans oil and needs to be boiled out occasionally.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Roger10378
Goodrich, MI.
Roger10378 wrote: I like to see trans temperature reach 220 occasionally. Water condenses in the trans oil and needs to be boiled out occasionally.
I like your theory, but in 30+ years of driving and exclusively wrenching on all my own stuff and some for others, I have never come across that issue in any vehicle new or old save for maybe one that was severely neglected.
And if it was even remotely an issue, I don’t believe most auto trans mfgs would design them where they ideally Never reach anywhere near that high of oil temperature.
2017 Heartland Torque T29
8 miles at 8% under a load will clean the cobwebs out of most vehicles.
What temps do you run, say on a 4-6% at highway speeds?
Also, 3000rpms is nothing for a LS motor. If you dropped it another gear, the trans would run a bit cooler.
Now if you’re pulling steep grades frequently which you may be, presume a 6 speed suburban has an external cooler, I’d consider a larger cooler. Or another option, deep pan for more fluid capacity and a bit of cooling with a finned pan may yield similar results.
Microlite Mike
NW Washington State
Ideal operating temps for modern Automatic Transmissions are from 170F - 225F.
I wouldn't worry about 220F for a short time, especially when climbing a steep grade where temps tend to rise when pulling hard.
One important step when towing is to change fluids more often. Every fluid, engine oil, Atf, Engine Coolant, and Power Steering fluid take a beating under the heat created by towing.
On my vehicle I change Oil every 5K and ATF/PS/Coolant every 50k. So far my 19 year old truck (2004 Titan) tows my 6,000 trailer up anything I've encountered in the West.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
BarabooBob
Baraboo, WI
If I were towing with a V8 going up grades in the mountains I shift down to keep the rpm's up. This results in more HP and lower tranny temps. Your V8 probably puts out just over 200 HP at 3000 rpm's. Kick it down, rev it up a bit and you are making close to 400 HP and will top grades at whatever speed you want and the tranny will be cooler.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
