RV.Net Open Roads Forum: Fifth-Wheels: Slidouts
 > Slidouts
drb1251
Ohio
Posted: 05/08/22 04:50am Link  |  Quote  |  Print  |  Notify Moderator
Which is better electric or Hydraulic?
wanderingaimlessly
Buggs Island lake
Posted: 05/08/22 06:07am Link  |  Quote  |  Print  |  Notify Moderator
The answer depends,,,, here is a breakdown.
You tube
JIMNLIN
Oklahoma
Posted: 05/08/22 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Well.... they both run off electricity and Having had both I saw no difference in them.
If electricity isn't available most gear operated slide outs can be hand cranked in/out.
Some not all hyd units can have a bolt or some way in the hyd pump too allow moving in/out if electricity isn't available.
wildtoad
Blythewood, SC
Posted: 05/08/22 07:07am Link  |  Quote  |  Print  |  Notify Moderator
What’s a bit more important is who makes the slide mechanism, and did the RV manufacturer do a good job installing them.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Near Bishop, California
Posted: 05/08/22 07:46am Link  |  Quote  |  Print  |  Notify Moderator
The provision to hand crank in and out is far more important than equipment type IMO.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Curly2001
Tucson, Arizona
Posted: 05/08/22 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Not a fan of cable slides here in the heat if they use plastic cable pulleys. Guess I am not a fan of schwintek slides, either.....
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
goducks10
There
Posted: 05/08/22 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I've had rack & pinion slides on 3 different trailers for 111-12 years. None ever gave me an issue. I think it's the most reliable slide type made.
Hydraulic will add more $$ to the price of the RV. Never owned an hydraulic slide so can't comment on reliability.
valhalla360
No paticular place.
Posted: 05/08/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
They are all electric but different mechanics:
- Hydraulic
- Worm Gear
- Cables
- Schwintec (?)
Personally, like the worm gear ones.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Jim-Linda
Livingston, TX
Posted: 05/08/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Have a '98 HH with 3 hydraulic slides, no slide issues yet, I have changed fluid a couple of time and no leaks so far.
Jim
Tom/Barb
Oak Harbor, Wa
Posted: 05/08/22 10:04am Link  |  Quote  |  Print  |  Notify Moderator
our Newmar Mountain Aire has a total mechanical slide out.. driven by a single electric motor, in 22 years it has never failed.
 > Slidouts
