RV.Net Open Roads Forum: Class C Motorhomes: cricket golf cart for a rv
 > cricket golf cart for a rv
midnightsadie
ohio
Posted: 05/08/22 07:44am Link  |  Quote  |  Print  |  Notify Moderator
thinking of getting a cricket cart,there about half the size of a reg cart. there hauled on a carrier that goes in the 2in reciever. any pros or cons? on the back of a sprinter liesure travel van .
Bumpyroad
Virginia
Posted: 05/08/22 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I "assume" that is the same one discussed a couple of years back. IIRC had a choice of battery or gas. could move battery to RV to reduce load on hitch. don't remember any complaints/problems with it.
bumpy
rjstractor
Maple Valley, WA
Posted: 05/08/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I looked at the specs briefly. At 400-480 pounds it might be a little heavy, that depends on the weight capacity of your hitch and vehicle. The class C I used to have had a hitch weight capacity of just 300 lbs, yours might be more.
IAMICHABOD
Sunny So Cal
I looked into these a few years back,I liked the only one I got to see.
Here are some threads here that discuss them.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
midnightsadie
ohio
Posted: 05/08/22 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
bumpy no ,first time I heard of them was sat.
Bumpyroad
Virginia
Posted: 05/09/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I see they are powered with 3 12 volt batteries. that's a whole lot of weight before you add on the weight of the unit.
bumpy
bobndot
Posted: 05/09/22 09:21am Link  |  Quote  |  Print  |  Notify Moderator
Have you ever weighed your rv all loaded for a trip ?
Do you know that your rear axle and tire rating will support the weight of the cart, batteries, the addition of a rack and hitch head to haul it ?
Measure the dimensions of the cart to see how long the hitch shaft needs to be,
to fit the cart and rack so it does not hit the rv.
I would think the longer the shaft length needs to be will determine how the whole package removes weight off the front axle. That will determine how it will affect handling of the rv.
People tow cars all 4 down bc it has no hitch weight. What you want to do is hitch weight.
Dusty R
Charlotte Michigan 48813
Posted: 05/09/22 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Seams like I've seen a hitch platform with caster wheels.
bobndot
Posted: 05/09/22 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, i forgot about those carriers. That would be a Swivelwheel carrier. The single wheel model is $2200, the dual wheel model is $3800. On both models they use an 8” wheel. I don't know anyone who has used one and have never seen one being used while on the road. But , i guess it could be an option for the OP.
Some CG’s offer carts to rent as you need them. Some will charge you if you use your own. It has to be worth the investment to do this.
ron.dittmer
North-East Illinois
Posted: 05/21/22 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
I get the wee-bee-gee-bees when I see a lot of cantilevered weight on a hitch on any vehicle, but most especially with a class B or C motorhome. It doesn't sit right with me. A couple of bicycles or a light storage carrier is one thing, but a 400+ pound mini-golf cart hanging 2 to 3 feet away from the connection? Not so much. Consider that with the inherent leverage, it is going to be a lot more than 500 pounds at the point of connection.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
