RV.Net Open Roads Forum: Travel Trailers: 30A Surge Protector Recommendations
 > 30A Surge Protector Recommendations
CA Traveler
The Western States
Posted: 05/09/22 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Comparison chart https://www.rvupgradestore.com/Articles.asp?ID=279
2014 Grand Cherokee Overland
Bob
Boomerweps
Hills of PA
Posted: 05/09/22 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
I put the hard wired Progressive Industries HWC-30 in my TT. I cheaped out and didn’t get the remote display. Mistake.
Only problem is it does it’s job well. No ground, inverted polarity on the mains, NO POWER passed. No workarounds. Had low voltage at one place, it kept shutting off power. I suggest having a bypassable plug so you can get power in those odd cases IF you determine the risk is worth it.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
IAMICHABOD
Sunny So Cal
Posted: 05/09/22 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
This is one very good reason to have the remote display if you want to bypass the EMS and restore power and take the risk.
Former El Monte RV Rental
Buying A Rental Class C
Bobbo
Wherever I park
Posted: 05/09/22 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
As IAMICHABOD stated, there IS a bypass. It is part of the remote pendant that you didn't get.
Bobbo and Lin
cbshoestring
Penn Hills. PA
Posted: 05/09/22 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have to shut mine off when we boondock for four wheeling trips. The generator trips the unit for "open ground".
I'm normally only using the trailer for sleeping....with a space heater for heat. Maybe a bit of t.v. as I nod off. So I figure nothing important will get fried.
IAMICHABOD
Sunny So Cal
Posted: 05/09/22 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
There is a way around that, so you don't have to bypass the EMS,just make or BUY a grounding plug for your generator.
This Thread may be of help to you if you are interested in doing it.
* This post was edited 05/10/22 08:02am by IAMICHABOD *
cbshoestring
Penn Hills. PA
Posted: 05/10/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
I normally use CG pedestals with the better half, but have recently started making 1 or 2 trips a year with the brothers to do a bit of ATV riding. One brother kindly shares his generator, as we both set up for minimum power usage.
I may have to add a plug to the collection....we all keep.
* This post was edited 05/10/22 08:55am by cbshoestring *
Boomerweps
Hills of PA
Posted: 05/10/22 10:25am Link  |  Quote  |  Print  |  Notify Moderator
There were NO switches on the remote display whenever I bought my EMS. I’ll have to contact PI to see if the new remote is usable with my unit. IIRC, at the time I bought & 1st used my EMS, you could separately purchase the remote display later for near twice the additional cost buying it with the EMS.
Bobbo
Wherever I park
Posted: 05/10/22 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
I bought my PI EMS HW30C in 2008 with the remote pendant. It has the switch. Your PI must be really old, because mine is 14 years old. Here is a photograph of my pendant (note the lower left corner of the pendant):
CA Traveler
The Western States
Posted: 05/10/22 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
My 2005 HW50C remote has a switch.
