ernie1
Sacramento,California,USA
The key fob for my 2018 PleasureWay Sprinter built on a 2017 chassis has quit working even though I put in new batteries and cleaned the contacts that are accessible. In the beginning the problem was sporadic and now it's totally dead. I've also tried different new batteries with no luck. Mercedes says new key fob not available until January of 2023 at a cost of $218+programing.
I've tried to take the unit apart for removing the board but no luck.I think it's glued together. Are there any companies that repair these? Have any of you had your key fobs repaired? Has anyone successfully disassembled their MB Sprinter key fobs?
Check with the key fobs are us companies (not their real name) but there are companies that have fobs for dang near everything.. I know a new key for my Jeep is 50 bucks (but it is likely a different type) and I do not know how they match/program them. Sorry I did NOT bookmark the url.. I found 'em with Google.
Find out what models of Mercedes use the same fob and google for it.
wanderingaimlessly
Buggs Island lake
Amazon has listings for key fobs, I went there for new ones for my jeep. You likely will have to take it to a locksmith for programming after purchase. Have either the vehicle or at least the VIN with you when you go.
mgirardo
Brunswick, GA
Call a locksmith that programs keys, they might be able to find fobs. My son bought his first car, a used Volvo with push start a couple years ago. The dealer only had one key fob. The locksmith wanted $200 for 1 key fob. We were able to find key fobs on Amazon, $70 for 2. They look identical to the OEM key fob. The same locksmith charged $50 to program them.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Gjac
Milford, CT
Batteries Plus will fix and reprogram older key fobs. Newer ones require going back to the dealer.
markandkim
Swansea, MA.
Buy fobs on amazon. Transfer the circuit board and batteries to the new fob.
All set.
At least with RAM fobs.
Check it out.
Retired Navy
2020 Ram 2500 Bighorn 6.7L
2014 Crossroads Zinger 27RL
2022 Grand Design Reflection 315RLTS
AllegroD
Outdare
deleted
ernie1
Thanks everyone for your suggestions. Since my fob is newish(2017), I'm not finding a suitable replacement from Amazon or anyone. I'd like to be able to further disassemble the fob to access the circuit board but am not having luck and think the unit must be glued together.
wnjj
Cornelius, Oregon
ernie1 wrote: Thanks everyone for your suggestions. Since my fob is newish(2017), I'm not finding a suitable replacement from Amazon or anyone. I'd like to be able to further disassemble the fob to access the circuit board but am not having luck and think the unit must be glued together.
3 here on eBay with the lowest at $50:
eBay fobs
ernie1
wnjj: thanks for the link but those three are not the style of key fob I have.
