RV.Net Open Roads Forum: Travel Trailers: Leveling Issues
 > Leveling Issues
Webber229
Torbert LA
Posted: 05/09/22 04:28am Link  |  Quote  |  Print  |  Notify Moderator
During the process of setting up my TT for my WD hitch, while leveling front to back, I noticed that the passengers side of my TT un-coupled was 24 1/2" on the front pass corner from the frame to the ground and 23 1/2" on the rear pass corner from the frame to the ground. My drivers side however for a perfect 24" across the TT from the frame to the ground. The ground that I was doing this on was level (concrete driveway). My TT is brand new and I have yet to taken it on a trip. I also noticed that my rear bumper which is the 4x4" tube bumper is bent, higher on the drivers side, lower on passenger.
I guess the point of me posting since I'm new to the camper world is are all of these things normal for a new TT? I understand that these things are built on a assembly line so their not going to be perfect but I'm just curious.
I have a 2022 Jayco WhiteHawk 27RK.
Thanks.
1492
Arlington, VA
Posted: 05/09/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the forums. Moving your question to Travel Trailers.
BurbMan
Indianapolis, IN
Posted: 05/09/22 06:12am Link  |  Quote  |  Print  |  Notify Moderator
First thing that comes to mind is loading, is there anything heavy in the RR corner? Sounds like the RR corner has a 1/2" drop that is producing a corresponding rise in the RF corner. Maybe water tank is located there, at 8 lbs/ gal, a 50-gal fresh water tank then weighs 400 lbs.
I would also have a look at the right side suspension, spring hangers, equalizer, etc to be sure everything is bolted together right.
a 1/2" out-of-level by itself is not a huge deal as long as it's not a symptom of something more serious.
2008 Heartland Big Country 3250TS
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
schlep1967
Harrisburg, PA
Posted: 05/09/22 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Most "level" concrete driveways have some slope in them so water doesn't just lay on them. Borrow a 6 foot level from somebody and check the driveway before you fret too much.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
BurbMan
Indianapolis, IN
Posted: 05/09/22 06:38am Link  |  Quote  |  Print  |  Notify Moderator
The driveway isn't level per se, but it's flat, meaning that if he got the same F/R frame to ground measurement on the left side it should be the same on the right too if the TT frame is flat.
Webber229
Torbert LA
Posted: 05/09/22 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input, all of my tanks are empty as well and yeah it could be a loading issue, I didn’t think about that. And yes the concrete was flat but maybe it wasn’t perfectly level. Either way I think I should be getting the same measurements on all 4 corners of the frame if it was perfectly level. Also I got under my TT and didn’t notice any visible cracks in any welds and all of my leaf springs and suspension as a whole looks good as well. I will take a more detailed look at it again this evening!
JRscooby
Indepmo
Posted: 05/09/22 07:03am Link  |  Quote  |  Print  |  Notify Moderator
To declare concrete "flat" without checking is asking for trouble. Half inch in 8 feet is not much, and very common. If you want to check for level a tape measure is not the best tool.
valhalla360
No paticular place.
Posted: 05/09/22 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Being off by a 1/2" over 32ft is nothing on a typical driveway. Even over the 8.5ft side to side is far from a sure thing.
- It's certainly possible it's simply loaded a bit heavier on one corner.
- It might be variations in the pavement.
- It might be something wrong.
Even a 6ft level might not be accurate enough to detect 1/2" variation over 32ft.
Without getting complicated, trying to establish level to a high tolerance is going to be difficult. Unless there are signs of something obviously bent, damaged, misaligned, etc..., I'd probably call 1/2 inch good enough given the limitations of your means of measurement.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Guy Roan
Posted: 05/09/22 08:46am Link  |  Quote  |  Print  |  Notify Moderator
That bumper certainly is not normal !
Sounds like slip shod work at the factory
Guy
Webber229
Torbert LA
Posted: 05/09/22 10:04am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of the ideas! I defiantly feel a lot better now except for the bumper thing, I'm not sure how it happened. there is no signs for contact on the bumper from anything I guess it was just welded like that.
 > Leveling Issues
