stevenal
Newport, OR, USA
Pilot? How old a fridge are we talking about? Modern RV fridges use electronic spark ignition. When my old Dometic had check light problems, I tried blowing the flame out in an attempt to recreate the problem. It would simply spark and reignite. A Dinosaur replacement board fixed the problem.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
@adamis. Well stated!
2017 Heartland Torque T29
StirCrazy
Kamloops, BC, Canada
stevenal wrote: Pilot? How old a fridge are we talking about? Modern RV fridges use electronic spark ignition. When my old Dometic had check light problems, I tried blowing the flame out in an attempt to recreate the problem. It would simply spark and reignite. A Dinosaur replacement board fixed the problem.
the original poster had a 96, mine is a 91. my board will try to relight the piliot 3 times then go into error no DSI componants back then aside from the furnace. when I bought my 2006 Wave that was a luxery with all DSI apliances, was unheard of then for them to be included as standard and not just as an option.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
time2roll
I have read adding some fiberglass batting from a home furnace air filter to the inside of the lower vent will reduce wind buffeting when at speed.
Turn off the propane? Need to see that in the owners manual.
675w Solar pictures back up
StirCrazy
time2roll wrote: I have read adding some fiberglass batting from a home furnace air filter to the inside of the lower vent will reduce wind buffeting when at speed.
thats one thing I am looking at trying in june. I am going to actualy put a furnace filter inside the louvers and see what difference that makes. Some people speculate that it is coming from the top vent down also.. so I have to take a look at that end also.
Steve
