RV.Net Open Roads Forum: Fifth-Wheels: Removing Shower Doors
 > Removing Shower Doors
debili
Illinois
Posted: 05/11/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
After searching you tube for about an hour decided this might be best place to ask...
Full timer here going into fifth year...Single older woman so this is a DIY project.
How the heck do I get the shower doors off???
I have the 20011 Jayco RTLS 351 I think that is it...
it is corner shower with round sliding glass doors the track is nearly impossible to keep clan and at this point I m think I would like to remove and just have a shower curtain...
Any Help???
CA Traveler
The Western States
Posted: 05/11/22 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Maybe find out who made the door and someone who is familiar with that product. Pictures?
Their might also be a way to partially disassembly the frame to remove the door.
Or other cleaning methods including sprays, brushes like tooth brushes etc?
2014 Grand Cherokee Overland
Bob
schlep1967
Harrisburg, PA
Posted: 05/11/22 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
I would use a vacuum and a brush to clean the tracks. My first camper had a curtain. It had a tendency to suck in against you when you were showering.
Most sliding doors have adjustment screws top and bottom near the rollers. By loosening the screws you should gain enough space to take the door out.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
debili
Illinois
Posted: 05/11/22 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Well I have tried all that you both mention tooth brush sprays
we have well water here very limey I've used lime away Iron out but getting into the track is impossible!
It is a curved track with sliding doors if I can figure out how to upload a pic here...no I guess I can't there is no url for photos
CA Traveler
The Western States
Posted: 05/11/22 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
Picture posting https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/15775751.cfm
MNRon
Tennessee
Posted: 05/11/22 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
We removed the glass shower doors in our 2019 Vilano 320 and put an articulating rod and curtain in it's place; best mod (of many) we've made. More room when you're in the shower, more room in bathroom when you're not, no cleaning glass doors, and no *trying* to clean the track.
Not sure how it would work with a corner shower though. Recommend you search out a manufacturer specific forum and see if others have done this.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
C.B.
APPLETON WI USA
Posted: 05/11/22 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
I found this on rvforums.com
#2
If they are like the curved shower doors in our MADP, there are two plastic guides at the bottom of the door, one at each end. They are removed by taking out a screw on each one. Without the guides in place, the doors lift up and off the track, then pull out. Reverse the procedure to re-install.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
C Schomer
Pueblo West, Co.
Posted: 05/13/22 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
The center half of my glass enclosure was four glass panels that rolled. The design was easy enough to clean but I got tired of drying off all those glass sections so I replaced them with a curtain. I cut acrylic blocks to fit the track where the roller were to attach the curtain to. The curtain needed to be cut down narrower and shorter and I had my wifey sew a wide hem at the bottom so I could slide in weights. This is the third time I’ve replaced PITA doors with curtains and they are much better. Craig
Doors
Curtain
* This post was edited 05/15/22 03:09pm by C Schomer *
debili
Illinois
Posted: 05/16/22 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Lets see if this works...trying to add photos there is no larger space at top of the tract to lift the rollers out
debili
Illinois
Posted: 05/16/22 07:29am Link  |  Quote  |  Print  |  Notify Moderator
ok it did not resize photos so I apologize
