Silas Carpy
Elmira N.Y.
2009 fleetwood pulse, dewinterizing. Drained holding tank and low point valves. Filled tank half way, turned pump on pumped up pressure and stopped. Flush toilet pump and water run. Turn on shower, hot and cold, pump and water run. Turn on either sink, pump runs about 1 second, stops, no pressure to either faucet. Anyone have any idea as to cause?
way2roll
Wilmington NC
Did you put your winterizing valves back to the normal position?
ejmorgan
Dixon, CA
Perhaps the sediment screens in the faucet outlets are clogged. Unscrew them to inspect and clean.
Ed
Ed and Susan Morgan
TT -- 2019 Northwood Nash 24M travel trailer
TV -- 2004 Ford E-350 Extended Van, 6.8L V10, 4-spd. Automatic OD, 3.73 rear axle.
Generator -- Onan 3600 LP
Photo -- Doran Beach in Bodega Bay, Ca.
schlep1967
Harrisburg, PA
Your symptoms act like a failed check valve. Why a check valve would affect both hot and cold for only the sinks (assuming when you say both you mean bathroom and kitchen) is a head scratcher. If it is just the hot water it would be the check valve at the water heater out line.
2021 Chevy Silverado LTZ 3500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide 4500
MFL
Midwest
ejmorgan wrote: Perhaps the sediment screens in the faucet outlets are clogged. Unscrew them to inspect and clean.
Ed
Likely this is problem
way2roll
Wilmington NC
Or a leak somewhere.
Silas Carpy
Elmira N.Y.
Nailed it, sediment screens. Thank you.
Y-Guy
Tri-Cities, WA
Do check the sediment screen (if installed) on your pump itself. First trip out I had to dig around to clean mine out too. Was also my reminder to bleach the holding again.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
