RV.Net Open Roads Forum: Tech Issues: Tripping solar panel breaker
 > Tripping solar panel breaker
StirCrazy
Kamloops, BC, Canada
Posted: 05/13/22 08:41am Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
StirCrazy wrote:
I am looking at changing the controler to a MPPT so I can put them in series. in parralel with a 8 ga wire you are looking at losing up to 0.38V over 10 feet, in series that would be a voltage drop of 0.19. doesnt sound like much but it adds up..
Series also has greater shade tolerance/power with panels that have bypass diodes (most have them).
My 3 series 30V panels have 3 bypass diodes, so 10V per panel section. I've seen charging at 20V increasing in 10V increments to 90V due to a leafy shade tree. ie The 20V can be from 2 different panels. Parallel would require sun on the entire panel and hence charging would occur with 1, 2 or 3 panels with sun.
yup, I know that also, was just looking at the efficiency of voltage drop in this senario. also lowering the amps on his line.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
StirCrazy
Posted: 05/13/22 08:43am Link  |  Quote  |  Print  |  Notify Moderator
EMD360 wrote:
2oldman wrote:
I don't know why you have to fuse panels.
Apparently you don’t if wired in series. The amps are not high enough to damage the wires if there is a short circuit.
That’s what the windynation site that was shared explained.
I still did for mine, I did both the panel side and the battery side of the controler with manual tripable breakers so I can use them as a disconect if I have to do any work.
Steve
Housted
Los Angeles, CA
Posted: 05/13/22 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Steve
X2
2015 Dodge 3500 Laramie 6.7 CTD Tow Rig Integrated ball with Andersen Ultimate 5th Wheel hitch
2011 Arctic Fox 29-5T 5th - 4 Pt Leveling, Disk Brakes, 1050 W Solar,
300 Amps of LiFePO4,3000 Watt Inverter
  • pic
    Too many mods to Truck and trailer to list.
  • EMD360
    Arvada, CO
    Posted: 06/17/22 11:24am Link  |  Quote  |  Print  |  Notify Moderator
    Just reporting that the upgrade to a 30 amp breaker on the panel side worked. But of course the amps I was reading were below 15 when tested.
    2018 Minnie Winnie 25b New to us 3/2021
    Former Rental Owners Club #137
    2003 Itasca Spirit 22e 2009-2021
