MatthewThomas
FL
I was looking up the legal DOT heights (13.5ft) as well as the minimum recommended clearance between truck and bottom of the 5th wheel overhang (6in) then crossed it with the most recent height measurements for Ford trucks (no bias, just the first one I could find).
They don't have a direct measurement to the top of the bed but they had a measurement from open tailgate to ground 36.9in (F350 biggest wheelbase) then a height from the bottom of the bed to the top 21.1in, totaling 58in.
Adding the 6in for bed clearance - 64in.
Now take the federal max height 13.5ft (162in), and minus 2in (personal choice for peace of mind) which leaves 160in.
Minus the 64in and that leaves you with 96in or 8ft.
My question is, if you take off an extra foot for insulation and structuring (would be a bit excessive but using it for a more conservative outlook), could the interior of the overhang portion of the 5th wheel be 7ft?
Cptnvideo
Arizona - most of the time
Good question. But why 7 ft for the bedroom (in most 5th wheels)?
I just measured our floor to ceiling in our 2022 Grand Design Solitude 378 MBS bedroom and it is 6.5 ft (78").
Bill & Linda
Arizona
2019 Dodge Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1200 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
Veebyes
I am thoroughly confused. If you want to know your air draft simply measure from your highest point to the ground while hooked up.
How difficult is that?
2007 Alpenlite 34RLR
MatthewThomas
FL
Veebyes wrote: I am thoroughly confused. If you want to know your air draft simply measure from your highest point to the ground while hooked up.
Unnecessary, but this is theoretical, I don't have a unit, but am planning a build and want to know if my theoretical numbers make sense.
MatthewThomas
FL
Cptnvideo wrote: Good question. But why 7 ft for the bedroom (in most 5th wheels)?
I figured there is about 6ft or so for the overhang, which would make the dimensions of that space, 8'w by 6'd by 7'h. So a decent room.
Plus I'm 6ft2in so though 6ft6in isn't too bad, it's right above my head haha.
Cptnvideo
4" above your head sounds fine for a room that is only used for sleeping and getting dressed.
MNRon
Tennessee
There's usually an AC on top of that roof that you haven't accounted for
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
way2roll
Wilmington NC
I am also confused. Are you building a FW from the ground up? I am sure specs/dimensions are readily available for most production units. Why live in theory, go to an RV dealer and take measurements.
ACZL
UPstate,NY
My '17 F350 DRW 4x4, CC w/ 8' box and '18 Big Country comes in at 13'4" last time I measured it. The national bridge height is 13'6" not 13'5". BUT there is a built in add'l foot on MOST bridge clearance heights. We still have 6" of clearance from top of box to underside of 5er. One thing you have to take into consideration (unless you have airbags) is that the rear of the truck will squat down w/ 5er on so this brings down the top front height of your 5er. RV transporters don't have problems and they have all kinds of truck configurations. Just sayin'.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Cummins12V98
on the road
I am 13' 4" at highest point, my top of tailgate is 55" loaded or not and have 6" bed clearance. Never heard of anyone being higher.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
