Allworth
Orlando, FL
The Traffic Engineering Department agrees with Yahalla!!
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
jaycocamprs
Ringgold Georgia
MatthewThomas wrote:
Unnecessary, but this is theoretical, I don't have a unit, but am planning a build and want to know if my theoretical numbers make sense.
If you thinking of building a trailer, you need to look at this thread. BoonHauler BoonHauler was a member here but hasn't posted in years. From what I remember reading the build thread he really did it right. Took a good while but really looked good when he was done.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
msmith1.wa
Tacoma, WA
Some reading material regarding vertical clearance and max vehicle height.
FHWA vertical clearance
RVIA
Heavyhaul.net
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
MatthewThomas
FL
way2roll wrote: Thanks for the clarity. Keep us posted on your build. Never seen anyone build up a FW. Pretty interesting project.
I still think there is a ton of value in measuring real world units. Lots of engineers over decades have refined the design of current FW's.
Definitely will. The next time I go into town I plan on taking a measuring tape with me.
MatthewThomas
FL
Hey thanks for the material I'll definitely be giving it a look.
MatthewThomas
FL
Interesting literature. Even tells about permits and such if necessary. I really appreciate it!
TXiceman
Full Time RVer
Well, let's confuse the matter a bit more for the math challenged...
13.5 feet = 13 feet-6 inches = 4.1148 meters = 411.48 centimeters.
In either case, over this height does require an over height permit for travel. There are also legal limits, for width, length and weight before you will be required to have a travel permit and sometimes an escort service.
Enjoy the day folks.
Ken
Amateur Radio Operator.
msmith1.wa
Tacoma, WA
TXiceman wrote: Well, let's confuse the matter a bit more for the math challenged...
Ken
The threshold for needing an oversize load permit depends on the state you are in. Only looking at the height allowed. There are quite a few that allow 14ft and a couple that allow more, without a permit. Looks like Alaska allows 15ft.
TXiceman
Full Time RVer
I designed large packaged systems that we had to design with the transport means in mind and where it was headed. The shipping department handled all the logistics with the truckers. Before a loaded truck left the shop, we had the driver up top with a tape measure and to also check maximum with and overall length. We noted these dimensions on the way-bill so that he was fully aware of his load size.
One time we had an oversize load hit a bridge (it was over height, width, length and weight). It was winter, so we had to watch the axle load limits on certain roads coming from Toronto to the Texas Gulf Coast. The driver decided to get off his designated route and visit a girlfriend and found a bridge he would not fit under. It cost his insurance and trucking company about $350,000 for repairs on the equipment in 1977. The trucking company said he would never drive again in North America.
So, measure your rig yourself and watch the low clearances.
Ken
edited 05/15/22 05:14pm by an administrator/moderator *
valhalla360
No paticular place.
TXiceman wrote: One time we had an oversize load hit a bridge (it was over height, width, length and weight). It was winter, so we had to watch the axle load limits on certain roads coming from Toronto to the Texas Gulf Coast. The driver decided to get off his designated route and visit a girlfriend and found a bridge he would not fit under. It cost his insurance and trucking company about $350,000 for repairs on the equipment in 1977. The trucking company said he would never drive again in North America.
On the positive side, when an RV meets a bridge beam, it's just a matter of sweeping up the RV pieces and maybe a little paint to touch up the steel beams.
Now a big excavator with the arm up too high...that insurance company got to buy a new bridge as he was well into the 3rd beam before the arm ripped off. Even worse, it was put an expedited schedule because the freeway was being shut down. I was only involved in the traffic control for the response but I'm sure it was several million before it was all done.
Stay within 13.5 (13ft 6inch, etc...) and it's generally not a big issue. The rare bridges that are below that are typically heavily signed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
