Ed_Gee
Central Oregon coast
Just wondering: We have a 24 foot diesel class C with somewhat difficult to find tires = Hankook DynaPro RH12 195/75R16C . I am considering carrying a spare tire only ( no wheel ) due to weight issues.
My question: Do most tow truck operators have the capability to dismount and mount a new tire onto a wheel?
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
cbshoestring
Penn Hills. PA
Many trucking companies carry a spare. Just about any large fleet tire service can remove/remount a tire on the side of the road. Depending on tire location... they can do it without removing the rim from the vehicle.
rlw999
Washington State
I've seen the big truck tow trucks replace a wheel, not sure if the smaller operators will, not sure what size truck you need for your 24 ft, I'm assuming it's a Sprinter based RV.
But that wheel must weigh only 25 - 30 lbs (probably less than the tire), do you really need to save that much weight? That's only a few gallons of water.
Ed_Gee
rlw999 wrote: I've seen the big truck tow trucks replace a wheel, not sure if the smaller operators will, not sure what size truck you need for your 24 ft, I'm assuming it's a Sprinter based RV.
For the record, I want to occasionally carry the spare tire without wheel , fastened to my ladder and I don't want to put more than 30 pounds weight (tire weight) on the ladder.
BTW, RV is a Winnebago Fuse on a Ford Transit chassis.
rjstractor
Maple Valley, WA
Ed_Gee wrote: Just wondering: We have a 24 foot diesel class C with somewhat difficult to find tires = Hankook DynaPro RH12 195/75R16C . I am considering carrying a spare tire only ( no wheel ) due to weight issues.
No, you would need to request a service truck from a tire company to remount your spare. Depending on where you were this could add lots of time and expense. In your situation, I would find a way to transport a mounted spare tire.
bobndot
I had coach-net , the agent asked if my spare was mounted or did it need to be mounted.
She would have called a tire service rather than a tow service. But i guess it might be who is available to come out to help in your area at the time. These road service companies go down a list of providers until someone picks up the service call.
time2roll
Tell the tow company the situation and see what they can do. Can be done with the right hand tools.
675w Solar pictures back up
Tvov
CT
I don't know about "most", but the towing companies around me all seem to have tire mounting equipment back at their shop. I have not heard or seen them actually mounting a tire on a wheel / rim on the side of a road for smaller vehicles.
"big rig" towing and service companies can usually mount a tire on a wheel, and then mount it on a trailer or truck, out in the field.
Bringing a spare tire, not mounted on a rim, is an idea, but... it really is easier to carry a spare on its own rim.
When you say weight issues, is that because your camper is over weight, or you have trouble moving / carrying a mounted spare yourself? I know as I have gotten more "seasoned" in age I have learned to use crowbars and blocks of wood to help lift spare tires onto a vehicle.
2021 F150 2.7
ferndaleflyer
everywhere
I had occasion to have this done. The tire service guy arrived and had the new tire mounted and was gone in 30 min. Might I mention that it was raining!
BurbMan
Indianapolis, IN
You can find a tire service guy to mount a tire roadside but they don't have the ability to balance it roadside. If you have an issue with the front, it's going to be rough riding until you can find a shop to balance it. If you're going to carry a spare, I would have it already mounted and balanced so you can swap it out and keep going.
I carry this Safety Seal tire repair kit with me, so I can easily handle any flat tire. The only times you would need to swap the tire is in the case of a blowout or a puncture too close to the sidewall that can't be plugged. Blowouts are rare unless you're running overloaded or underinflated.
2008 Heartland Big Country 3250TS
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
