RV.Net Open Roads Forum: Tech Issues: No headlights problem please help
 > No headlights problem please help
jay_kinsaul
Ishpeming
Posted: 05/12/22 08:45am Link  |  Quote  |  Print  |  Notify Moderator
So I just got a 1984 pace arrow in like new condition and everything but the headlights are not turning on. The switch apparently works cause I can turn on my running lights and dash lights and it dims like it should just no headlights at all. I have even tried hitting the brights switch on the floor and it don't do anything either not even the lights for bright for brights light up. So none of the four headlights work dims or lows. Any pointers and advice would be greatly appreciated
jdc1
Rescue, Ca
Posted: 05/12/22 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Start by disconnecting the wiring. Clean those connections with baking soda and water, then apply dielectric grease when re-assembling.
Matt_Colie
Southeast Michigan
Posted: 05/12/22 10:00am Link  |  Quote  |  Print  |  Notify Moderator
Jay,
You don't say what the chassis but most have the headlights on a separate fuse that is in the fuse group. Now you just have to find it and hope it is bad and that is all that is wrong.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
RLS7201
Posted: 05/12/22 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Jay,
Matt
Headlights are NOT fused. The lead for the headlight switch comes straight from battery power. The headlight switch does have a circuit breaker built in.
The headlight switch does have separate circuitry for the headlights and the parking/running lights. So the switch may be bad, even if the running/dash lights work.
You need to get out your VOM and check for voltage all along the wiring path for the headlights.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
jay_kinsaul
Ishpeming
Posted: 05/12/22 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
It's got the Chevy chassis wit the 454. I saw somewhere on Google that there's a circuit breaker on the switch itself
Krusty
Calgary, Alberta,Canada
Posted: 05/12/22 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Check for power at your high beam switch with the headlamps on. Should have 12 volts going in and it'll have 12 volts coming back out on either the high beam circuit or the low beam circuit. Also check the connector down there for corrosion and wires broken off
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
jay_kinsaul
Ishpeming
Posted: 05/12/22 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I will have to check that next time I go to it. I hear the switch work but like I said the blue light indicator for brights don't come on
allbrandauto
maryland
Posted: 05/12/22 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
most chevys used a fusible link at the starter motor
Posted: 05/12/22 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
There may be a fuse or breaker.. There may also be a relay in the main chassis fuse box (or elsewhere)
True story... My 8.1L Vortec (Chevy) engine would not crank (starter not engaging) I heard a sharp CLICK. not a CLUNK but a CLICK.
Pulled the starter pilot relay out of the fuse box.. Cleaned contracts. (I have the tools for that) replaced. Varoom.
jay_kinsaul
Ishpeming
Posted: 05/12/22 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah it's crazy how good of shape this thing is in it's like a time capsule. The carpet is like new and all the original appliances still work. Has 23,000 miles on odometer and 49 hours on generator. Changed the fuel filters and now runs and stops great for $200
