Near Bishop, California
This was a classic purchase on your part. Congratulations!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
ROBERTSUNRUS
Salem, Oregon
RLS7201 wrote: Matt_Colie wrote: Jay,
You don't say what the chassis but most have the headlights on a separate fuse that is in the fuse group. Now you just have to find it and hope it is bad and that is all that is wrong.
Matt
Headlights are NOT fused. The lead for the headlight switch comes straight from battery power. The headlight switch does have a circuit breaker built in.
The headlight switch does have separate circuitry for the headlights and the parking/running lights. So the switch may be bad, even if the running/dash lights work.
You need to get out your VOM and check for voltage all along the wiring path for the headlights.
Richard
Hi, this is the correct answer; Also when you remove the headlight switch, look for a melted connector.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
allbrandauto wrote: most chevys used a fusible link at the starter motor
For the headlights? Don't think so.
70s/80s GMs and probably other mfgs, power supply to the headlights goes straight through the switch. (The reason they make cheap relay harness kits now to boost power to the headlights)
Most likely is a failure in the headlight switch itself (I think?)
but trace power in and out of the switch to verify that.
2017 Heartland Torque T29
Or, old GM headlight switches are so cheap, just slap a new one in and see if it works.
If it's the same as the cars and trucks, there's a little trick to getting the knob to release. Easier for you to look it up than explain.
RLS7201
Do you know how to remove the headlight switch? Pull knob all the way out, get your fingers on the back side (flat side) of the switch and push the little spring loaded button and then pull the knob out. Then you can undo the nut that holds the switch assemble in place.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
allbrandauto
maryland
Grit dog wrote: allbrandauto wrote: most chevys used a fusible link at the starter motor
Roger10378
Goodrich, MI.
For safety reasons all headlights are on self resetting circuit breakers. Most of them are part of the switch.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
