RV.Net Open Roads Forum: Propane shut off valve opens on its own
 > Propane shut off valve opens on its own
Posted: 05/15/22 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, that makes a bit more sense.
I've never seen a propane tank valve that vibrated open, so it seems kinda strange.
Would think that is only possible when driving/vibrating. Maybe onboard generator causing vibrations?
Take this advice with a grain of salt, but if it's actually opening on it's own, I'd safety wire it if you continue to use it.
dedmiston
Coast to Coast
Administrator
Posted: 05/15/22 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Brownleaf wrote:
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing. I live alone and know little about computers. I say all to explain why I am not more verbose about issues. I may have bigger issues with my lp system. I am still checking to see if the valve closure was an error or it takes weeks to slowly open on its own. my 04,24 ft winnie stays in my driveway and I like to drive it once a week. I am doing various proejects such as recaulking and now rust removal from undercarriage. Doug
Hang in there Doug.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Brownleaf
Durham
Posted: 05/15/22 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog, gennset was removed but drive could have caused it. So even if it is opening on its own, you are saying the leak detector going off is a down system issue. The tank is basically empty right now. If there is a tiny amount in it would it be unsafe to try a stove top burner? And in fact should I open it up to see if that leak detector comes back on? Doug
Posted: 05/15/22 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
Presumably the leak detector is inside the camper and the valve/tank is outside, open to the air? Yes, a leak, if there is one, is likely downstream of the valve on the tank. (That could be leaking too? but not likely detected inside).
Since you're planning/needing to do work to the tank/valve it seems, I'd see what's left in it.
Turn it on and try to fire up the stove is a good way to tell.
FWIW, one can smell a very small amount of propane, but the concentration would have to be a major leak or leaking a long time and not vented to get to be enough to explode.
Or just unhook the line after the valve and vent/run out any residual gas in the tank. No smoking! LOL
I thought you had been using it regularly. My bad
You need to empty it anyway if you're doing rust work. and once it's empty you can easily replace the valve if it's giving you problems.
(I say easily, but I'm used to working on about anything that needs built or fixed, so idk what your comfort level is)
Brownleaf
Durham
Posted: 05/16/22 11:54am Link  |  Quote  |  Print  |  Notify Moderator
All good info. i did use the furnace this winter to avoid too low temps in rv. It seemed like the propane emptied out faster than last year. Good idea on disconnecting while doing rust removal and repainting of tank. Doug
mgirardo
Brunswick, GA
Posted: 05/17/22 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Assuming this is a laptop, keep your palms up when you type. It sounds like part of your hand is swiping the mouse pad as you type and causes the cursor to move, possibly selecting text. Then when you type the next letter, whatever text was selected gets deleted. You can also buy a desktop style keyboard (wired or wireless) and you won't have that problem anymore.
If going wireless, might as well get a keyboard and mouse combo, then you don't have to use the laptop's keyboard and mouse pad. Some laptop mousepads are a real hassle.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Brownleaf
Durham
Posted: 05/17/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Mugirardo, it is a chrome book so just using a keyboard. Just now I typed an M and it wanted to jump back to the front of your name. On a previous post I hit the insert sign above the 6 and it deleted the whole paragraph that I had written. if getting a new chrome book eliminates these problems For Good I will do it. Doug
