RV.Net Open Roads Forum: Propane shut off valve opens on its own
 > Propane shut off valve opens on its own
Brownleaf
Durham
Posted: 05/12/22 09:32am Link  |  Quote  |  Print  |  Notify Moderator
On my motorhome ( perm. tank), I discoveed that my shut off valve opens back up partially after having been closed earlier. Is this an easy - simple relacement? Expensive? Doug
Matt_Colie
Southeast Michigan
Posted: 05/12/22 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I had to replace mine and the part was about 80$us and shop didn't change me any labor, but I would not count on that.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
Brownleaf
Durham
Posted: 05/12/22 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, will pursue. Doug
steveh27
Grosse Pointe Woods, MI
Posted: 05/13/22 04:14am Link  |  Quote  |  Print  |  Notify Moderator
Matt
Matt, Where did you have that done? We are close & I may need it.
Posted: 05/13/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Would this be the same LP tank that you couldn't get filled, too rusted out, scenario form a couple months ago?
Skibane
San Antonio, TX
Posted: 05/13/22 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Is the valve handle actually turning on its own, or is the fully-closed position changing over time?
* This post was edited 05/13/22 10:36pm by Skibane *
Matt_Colie
Southeast Michigan
Posted: 05/13/22 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
steveh27 wrote:
Matt
Steve, I contacted a nearby bulk propane supplier. Bad news right up front, the company changed names and won't deal with me anymore because I am not a fixed tank customer. I had to remove the tank and bring it to them for them to do the valve swap. I don't know where to send you now.
Push comes to shove, you can try Cinnabar in Sandusky MI. They are up in the thumb and they work on motor homes.
Matt
Brownleaf
Durham
Posted: 05/13/22 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Skibane, i was sure i had turned it off and came back later to find it open most of a turn. I THINK this happened twice. However, since I last closed it all the way this has not repeated. i will just have to keep checking it. I am not using it now but in the winter it seemed like the propane was being used up fast. i did have some beeping on a very old leak detector relative to this recent discovery of the partially opened valve. Either I was careless or it opens on its own gradually. i definitely will be getting a new kidde multi gas detector soon. Doug
Posted: 05/15/22 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Dude, if you have to close the valve at the tank to prevent it from leaking somewhere downstream, you have bigger, more dangerous issues.
But then again, alot of what you are saying doesn't exactly make sense, like now not winter, so not using propane?
You obviously have an old moho, which presumably has other LP appliances (water heater, fridge, stove?)
And you are presumably camping or living in it, as your question(s) relate to active use of the camper, so to say the least, you leave alot to the reader's imagination as to what could be or is actually going on...
Brownleaf
Durham
Posted: 05/15/22 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog, my biggest problem is with my computer, as I will type out a paragraph and the unit will delete everything I just wrote or write back over what I am writing. I live alone and know little about computers. I say all to explain why I am not more verbose about issues. I may have bigger issues with my lp system. I am still checking to see if the valve closure was an error or it takes weeks to slowly open on its own. my 04,24 ft winnie stays in my driveway and I like to drive it once a week. I am doing various proejects such as recaulking and now rust removal from undercarriage. Doug
