Peter_Crowl
Alabama
I love the split systems that I have in my home.
Now that I have the roof on my 2000 Bounder 34T cleared for recovering I'm wondering if anybody makes an inverter system unit for RV's.
Searched around the net but came up empty.
CA Traveler
The Western States
If you mean one that runs on 12V DC inverted to 120V AC that would be rather inefficient vs a DC motor or just a AC motor.
A 120V 10A AC draw for a air conditioner would draw about 110A DC which would among other things require very large wires to the roof.
2014 Grand Cherokee Overland
Bob
Peter_Crowl
Alabama
CA Traveler wrote: If you mean one that runs on 12V DC inverted to 120V AC that would be rather inefficient vs a DC motor or just a AC motor.
No - one with an inverter compressor as used in a ductless split system. They are much more efficient. Rather than the compressor running on a start/stop basis - with the startups drawing the most current of the entire operation - they're a DC system that throttles the speed of the compressor to match the load. My residential units could run on the smallest Harbor Freight generator they offer.
JRscooby
Indepmo
Some talk of running AC off a generator. Most suggest engine rotation spin coils to make 120V which spins coils to pump refrigerant. Others engine rotation spin coils to make 12V which spins coils to pump refrigerant. Why does nobody in the RV world even think about engine rotation pump refrigerant?
valhalla360
No paticular place.
I've not seen an RV specific unit but in Kuwait, I've seen residential units mounted on the rear bumper. If you have room, you could put it on the A-frame at the front of the trailer.
I assume the trick would be finding a wall with no obstructions to mount the interior part of the unit. Running the lines between should be fairly straight forward.
I do like the idea of one less hole in the roof.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
way2roll
Wilmington NC
You lost me at ductless. Mini splits are great for rooms or garages but when trying to cool an entire RV with different rooms I think they lose some appeal - at least for me. If I were doing a Sprinter conversion I would definitely consider it.
time2roll
There are ceiling cassette vents used with some split units in place of the more common wall mounted. The highest SEER rating seems to be 240v units.
675w Solar pictures back up
theoldwizard1
SE MI
Peter_Crowl wrote: I love the split systems that I have in my home.
There are some 12VDC or 24VDC A/C systems designed for trucks, but nothing in the RV specific market.
Some people have taken residential mini-split systems which do use inverter powered compressors and installed on RV. Not sure how well they would handle all of the bouncing around.
If you are a HVAC person, it would not be difficult to build your own. All of the parts are readily available.
You can of course run an A/C off of an inverter if you have a large enough one and sufficient battery power.
The big win on 12VDC compressors is that they actually use 3 phase AC motors. 3 phase motors are much more energy efficient than straight DC or single phase AC.
pianotuna
Regina, SK, Canada
Here are a few battery powered air conditioners. Fairly pricey.
https://www.nomadiccooling.com/?gclid=Cj........O1GMjaSCR2eba9xZzSOgYyTqhv0aAtbXEALw_wcB
Regards, Don
Slownsy
Many people in Australia has installed the household inverter type revers cycle 240V air conditioning in there FW, and also now’s of one using the roof type cassette, not heard of any failure for several years. I and many others have also installed household 240V inverter refrigerator which runs of a 350-375W inverter.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
