RV.Net Open Roads Forum: Want to insulate front of class A (dog house?) with what?
 > Want to insulate front of class A (dog house?) with what?
dcason
New York
Posted: 05/14/22 03:45am Link  |  Quote  |  Print  |  Notify Moderator
For colder weather camping, we are looking to insulate the front area below big front window of our class A. What does hubby need to use? I assume we remove from inside? Thanks!
Donna
Our Blog
rgatijnet1
Posted: 05/14/22 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Our biggest heat loss was the insulation in the front cap, above the windshield. Behind the cabinets the fiberglass insulation shifted and was basically useless. I bought some two part foam insulation and sprayed a thick layer of foam insulation on the entire front cap. Problem solved. Two part foam insulation kits are available on eBay. This also works for the same issue with the rear cap.
midnightsadie
ohio
Posted: 05/14/22 05:39am Link  |  Quote  |  Print  |  Notify Moderator
theres a product called arm a flex .its flat sheets of dense foam. you spray glue on the surface then press it on as needed works great and a very good sound deading product.
BluegrassBill
Woodland, Wa. USA
Posted: 05/14/22 06:50am Link  |  Quote  |  Print  |  Notify Moderator
There is a product for insulating car hoods. Dense foam on one side and foil backing the other. I used this for my Itasca P32 Motorhome works great. Summit Auto used to carry it.
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
MountainAir05
New Mexico
Posted: 05/14/22 07:50am Link  |  Quote  |  Print  |  Notify Moderator
https://www.dynamat.com/
did ours and no issues since.
cptqueeg
Idaho
Posted: 05/14/22 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Which dynamat product did you use?
MountainAir05
New Mexico
Posted: 05/14/22 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Dynamat Xtreme Marine/RV Soundproofing. (I found the receipt) I also did my sports car in the 1/4 I think it was. Pulled the seats and carpet and cover all bare metal inside and outside of the car. Had a lot of road noise.
I call and talk to them and told them what I had and they told me what to get.
* This post was last edited 05/15/22 09:39am by MountainAir05 *   View edit history
cptqueeg
Idaho
Posted: 05/15/22 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
^Thank you.
