RV.Net Open Roads Forum: Tech Issues: AGM Deep Cycle batteries
 > AGM Deep Cycle batteries
ivbinconned
highway 16
Posted: 05/14/22 10:24am Link  |  Quote  |  Print  |  Notify Moderator
My flooded batteries are toast in the trailer.
I have been buying AGM starting batteries for boat and truck and like them. No maintenance and no corrosion.
Thinking of going to two. 6 Volt AGM batteries for the trailer.
Would this be a good choice?
How do they handle freezing temperatures?
Ram and 34 ft Cedar Creek
Cambria, California area
Posted: 05/14/22 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Fully charged wet and AGM batteries won’t freeze. Watch your prices. Two good AGMs will be close to one Lithium battery.
corvettekent
Marysville, WA
Posted: 05/14/22 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I think you are better off staying with flooded lead acid batteries. Two (or four) 6volt golf cart batteries. They are half the cost and I get 6 or 7 years out of mine before I replace them.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
RLS7201
Posted: 05/14/22 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
It's all about cost ver. your time for maintenance. I'm like corvettekent. I go for cost........
The post telling you to convert to lithium will be coming along shortly. GRIN.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
#1Flyboy
California
Posted: 05/14/22 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
…. I also like AGM for multiple reasons.
ivbinconned
highway 16
Posted: 05/14/22 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I asked 2 questions but have 1 more.
Are they compatible with any “converter”?
toedtoes
California
Posted: 05/14/22 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
I have AGM batteries for my engines and house batteries. I have been quite pleased with them. For me, the lack of maintenance needs is worth it to me.
They work with any converter. Your only consideration is battery size - make sure they will fit in your battery compartment.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 05/14/22 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my 4 12V Flooded with 4 6V AGMs 3 years ago this July and not crawling into the front battery compartment to check and add water is worth every extra penny the AGMs cost. I went with Trojan T105 @ 230 AH.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Ed_Gee
Central Oregon coast
Posted: 05/14/22 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
AGM batteries are lead acid chemistry....just like wet cells. Should be OK with your converter, but you did not tell us what your converter is. Modern converters usually have a switching setting for wet cells or AGM. AGM batteries have a slightly different bulk charge/absorb charge requirement than wet cells.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
ivbinconned
highway 16
Posted: 05/14/22 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
The converter is a WFCO 55 amp. I’m sure it’s original In a 2009 Cedar Creek.
Seems to me this converter will not start to even charge if the temps are really low.
