jodeb720
Denver
I remember reading this a while ago - there are two types of roof's installed on RV's. EPDM and something else.
I know 2Oldman is the king of all searches - but I'm not that good.
I remember the way to differentiate was the coloring on teh back.
Today I pulled one of my vents off and found the color on the a "blackish" color. Which roof type do I have -
And as long as you're reading this.. What adhesive do I use to reattach a replacement piece to the sub-straight base?
Thanks
Josh
fj12ryder
Platte City, MO
The other type is TPO. That's as much as I know.
Howard and Peggy
"Don't Panic"
IAMICHABOD
Sunny So Cal
Sure fire way to tell,this link will tell you What kind of roof you have
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Bobbo
Wherever I park
EPDM
TPO
Fiberglass
Aluminum
I would avoid the first two. My first RV, a Winnebago had a fiberglass roof. The same stuff that was on the sidewalls. My current Airstream has aluminum. When shopping I immediately ruled out anything with EPDM or TPO.
Bobbo and Lin
valhalla360
No paticular place.
Bobbo wrote: EPDM
TPO
Fiberglass
Aluminum
While I would prefer fiberglass or aluminum, for the cost to upgrade to a rig that has them, you could replace the rubber roof options several times over.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Near Mammoth, California
I wish I could afford an AS with an aluminum roof and body!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
dougrainer
Carrolton, Texas
Bobbo wrote: EPDM
TPO
Fiberglass
Aluminum
Please explain the basis for your comment. I have over 43 years as a RV tech. I have seen ALL roof materials. While I also would prefer Fiberglass, I would NOT like Metal roofs. Metal roofs will be damaged by normal size Hail that would dent a car. Fiberglass, rarely. It takes a LOT to punch holes thru fiberglass. It takes a LOT for Hail to damage a TPO/EPDM roof. For cost, I would like a EPDM/TPO roof. Your Airstream, the COST basis alone makes a Metal roof standard. Doug
Bobbo
Wherever I park
dougrainer wrote: Bobbo wrote: EPDM
TPO
Fiberglass
Aluminum
The basis for my comment? Personal preference. While I know that a good hail storm will dent my aluminum roof, I would be REALLY surprised if it punctured it. Dents, I can live with. You state that "{i}t takes a LOT to punch holes thru fiberglass." I posit that it takes more to punch a hole through aluminum.
jodeb720
Denver
OP here -
First thanks to IAMICHABOD that link told me I have an EPDM roof - Now the follow up question - what adhesive is the correct one to repair a section of the roof?
Thanks!
josh
dougrainer
Carrolton, Texas
Bobbo wrote: dougrainer wrote: Bobbo wrote: EPDM
TPO
Fiberglass
Aluminum
The Aluminum can get "cuts/cracks" instead of holes. While you state a Hailstorm will dent your roof. Well, A/S's do NOT just get dented roofs. Depending on which way the storm is blowing you get hail damage on various sides also. Regular RV's (very few metal sides left) just get roof top hail damage unless Fiberglass. Doug (we also service/sell A/S)
