RV.Net Open Roads Forum: Tow Vehicles: I am the truck killer!
Search only in Tow Vehicles
 > I am the truck killer!
RetiredRealtorRick
St. Augustine Beach, FL
Posted: 05/16/22 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
Hate to be the bearer of bad news on your ol' 2002, but if you haven't replaced the brake lines or fuel lines that will be next...
If he waited 20 years to replace plugs and wires, maybe the OP just isn't that much into truck maintenance --- just sayin'
. . . never confuse education with intelligence
mkirsch
Rochester, NY
Posted: 05/17/22 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I haven't owned it 20 years. Actually I'm not sure if it's 10 or 12. Bought it with 38,000 miles on it.
It's only got 51,000 miles on it now and has never been run in the salt. Those plugs and wires should have been good for another 49,000!
Oh and the brake lines went 8 years ago. Fuel lines are MINT.
jerem0621
Tennessee
Posted: 05/18/22 11:58am Link  |  Quote  |  Print  |  Notify Moderator
So sorry for your troubles!
I have a buddy who has a lifter fail on his 2020 Silverado. Instead of waiting for the truck to get repaired he traded it in on a new ZR2 Silverado.
200 MILES on the new truck.
~ Lifter Failure ~
On the other hand the 2.7l has proven extremely reliable and capable. I’m recommending them to anyone looking for a newer GM full size truck.
They do have DOD but it’s controlled by the cam not the lifter. Seems to be a much more reliable system.
Thanks
Jerem
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
It’s Kind of Fun to do the Impossible
~Walt Disney~
Posted: 05/18/22 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
~ Lifter Failure ~
Thanks
Jerem
Buddy with more dollars than sense. Which makes it even funnier!
New ZR2s are cool looking trucks with a lame designation. ZR2 conjures up images of 20 year old S10 blazers!
2017 Heartland Torque T29
Posted: 05/18/22 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
At least the 02 isn’t a Ford. If it was, half the 20 year old spark plugs would have stripped out and the other half would have snapped off! (Except maybe the ones that blew out of the head already!
bguy
The Rock
Posted: 05/18/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
What is causing these failures?
I thought that was a Hemi thing?
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Horsedoc
Dixie --- N. Georgia
Posted: 05/18/22 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Back years ago when I was young (and did crazy things) I heard of pushrods getting bent when hydraulic lifters would allow them to float and bad and expensive things happened. That was usually on cases of a heavy foot on the accelerator and the engine just over revving. Buddy put solid lifters in a 390 ford engine and stopped that but it sounded like a pea-thrasher sitting there idling.
Sorry for your troubles brother, it did bring back some long ago memories though
BenK
SF BayArea
Posted: 05/18/22 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Cam/Lifter design has the lifter slightly off center to have the cam lobe ‘turn’ the lifter to distribute the wear…old days
With today’s lifters fitted with rollers, wondering if the lifter somehow gets off line and the roller tries to ‘go thataway”, while the cam wants it to ‘go thisaway”
Why OHV can rev higher vs pushrod configuration
-Ben Picture of my rig
rjstractor
Maple Valley, WA
Posted: 05/18/22 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
dodge guy wrote:
3 GMs 3 problems. Time for a different brand.
Lol I was thinking same thing!
mkirsch
Rochester, NY
Posted: 05/19/22 06:04am Link  |  Quote  |  Print  |  Notify Moderator
GM mechanic told me they "swell" in the bore because they're hollow hydraulic roller lifters.
If they were solid roller lifters, no problem.
If they were straight hydraulic lifters, no problem.
The combination of the two is what's the issue.
