RV.Net Open Roads Forum: Fifth-Wheels: Nose High vs Bed Clearance
 > Nose High vs Bed Clearance
Rollochrome
Fort Worth, Texas
Posted: 05/16/22 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
Had a Reese Goosebox installed today.
Tell me your opinion here.
Am I too high in the front?
Trailer is 44' long, which makes a difference.
Frame bottom to ground in rear: 22.25"
Frame bottom to ground in front: 26"
Bottom of gooseneck to top of truck bed rail: 9"
Think I am GTG or do I need to drop the Reese down a click?
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
Near Mammoth, California
Posted: 05/16/22 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
A picture would help us. Ideally you are level to very slightly nose high…very slightly.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
Posted: 05/16/22 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
While you may be good, I'd drop the front a bit more. Nine inches clearance not really needed. Six usually okay, seven is great, most cases.
Jerry
BB_TX
McKinney, Texas
Posted: 05/16/22 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
2” drop should give 7” clearance and get you close to level.
fj12ryder
Platte City, MO
Posted: 05/16/22 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto to the above.
Howard and Peggy
"Don't Panic"
TXiceman
Full Time RVer
Posted: 05/16/22 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Go ahead and drop your nose down. 6 or 7 inches is adequate for bed clearance.
Ken
Amateur Radio Operator.
