Rollochrome
Fort Worth, Texas
Had a Reese Goosebox installed today.
Tell me your opinion here.
Am I too high in the front?
Trailer is 44' long, which makes a difference.
Frame bottom to ground in rear: 22.25"
Frame bottom to ground in front: 26"
Bottom of gooseneck to top of truck bed rail: 9"
Think I am GTG or do I need to drop the Reese down a click?
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
Owens River area
A picture would help us. Ideally you are level to very slightly nose high…very slightly.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
While you may be good, I'd drop the front a bit more. Nine inches clearance not really needed. Six usually okay, seven is great, most cases.
Jerry
BB_TX
McKinney, Texas
2” drop should give 7” clearance and get you close to level.
fj12ryder
Platte City, MO
Ditto to the above.
Howard and Peggy
"Don't Panic"
TXiceman
Full Time RVer
Go ahead and drop your nose down. 6 or 7 inches is adequate for bed clearance.
Ken
Amateur Radio Operator.
