RV.Net Open Roads Forum: Travel Trailers: Data plate
 > Data plate
Ronporter
Tucson
Posted: 05/19/22 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1995 Cobra 24 ft pull behind trailer. I can not find the manufacturers data plate. Can anyone tell me where it is located?
BobsYourUncle
Calgary Alberta Canada
Posted: 05/19/22 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Have you looked on the sides of the unit, maybe near the front. Many I have seen have a plate or a sticker with the info.
Also, on the inside of a cabinet door they sometimes put a build sticker sheet
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
bucky
Raleigh metro
Posted: 05/20/22 04:16am Link  |  Quote  |  Print  |  Notify Moderator
If it's an exterior sticky it's likely faded away by now. If it was typed rather than inked you may be able to make it out even after all these years. Check the entry door frame with the door open, I've seen some there.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Gdetrailer
PA
Posted: 05/20/22 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Data stickers (with VIN and tire sizes) have been traditionally placed on the drivers side sidewall at the front lower corner of the trailer. Typically the stickers fade out or peel off over time, so fair chance there is no sticker left on yours given the age.
Sometimes the sticker may have been placed on the drivers side of the tongue A frame and with some of those it may be a aluminum plate riveted in place.
The serial number (which on older trailers was the VIN) or VIN is often stamped in to the top or side of the tongue A frame and sometimes will be stamped on a aluminum tag and riveted to the tongue A frame.
Not sure what info you seek that will be on the sticker, typical info is VIN, tire size, air pressure for the tire size and GVWR..
Old ones like yours did not list unladen weight, tongue weight.
For GVWR you can count the lugs on your tire rims, 4 bolts you have axles of 3,000 lbs or less, 5 bolts you have axles of 3,500 lbs and 6 bolts you have axles of 5,000 lbs each..
Add up the axles and you will be in the ball park for GVWR and the trailer unladen weight should be less than GVWR..
To get unladen weight take it to a scale and get it weighed..
Many of the trailers made after 2000 may have an additional label in one of the kitchen cabinets as eventually someone figured out that stickers on the outside fade away..
 > Data plate
