RV.Net Open Roads Forum: Tech Issues: Easy toilet fix
 > Easy toilet fix
2oldman
NM
Posted: 05/20/22 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I may have mentioned this somewhere else, but I will again.
My Dometic 310 toilet was leaking, so I decided to try to replace the seal. I'd done all the cleaning, vinegar.. whatever.. but nothing worked. As per the youtube instructions I tried pushing down on it but it just would not come loose. I stopped after several minutes because I feared it would break and drop into the tank.
I wondered if what I did would make a difference, so I put water in it and, lo and behold, it held! Weeks later it's still not leaking a drop.
So.. if your toilet leaks and nothing works, just try pushing down on the seal.
mockturtle
AZ
Posted: 05/20/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the tip. I'll remember that next time it happens.
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
Southern California :(
Posted: 05/20/22 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Good idea. TY
Cummins12V98
on the road
Posted: 05/20/22 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have no idea what you were doing to your toilet. It's a ball and flush ball seal combo. The seal is set into a lip. To remove wear a glove it you choose and grab the edge of the seal and pull towards the center of the hole and remove.
Now the seal is removed scrub it til it's clean. Now apply a thin layer of Vaseline to the bottom surface and carefully install with the ball closed by pushing it into place. Once mostly set open the ball and finish pushing the seal into place. Always be careful NOT to drop the seal down the hole!!!
You probably just knocked off some of the crystalized "STUFF" when pushing on the seal.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Scottiemom
Posted: 05/21/22 05:42am Link  |  Quote  |  Print  |  Notify Moderator
I had the seal shift on my toilet and the flange stuck and the lever would not open it. I tried everything I could to dislodge it, but it just didn't work. Later my sister went in there and worked her magic. Pressed down on it while pulling the lever and it released! So I got out my info on the toilet and it says to use a silicone based lubricant and use it regularly to keep that seal working properly. I actually found some actual toilet seal lube at Camping World and used it. I haven't had any trouble with it since.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
udidwht
Seattle
Posted: 05/22/22 12:58am Link  |  Quote  |  Print  |  Notify Moderator
Use either Vaseline or Super lube.
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
Tom_M
New Hope, MN
Posted: 05/22/22 04:02am Link  |  Quote  |  Print  |  Notify Moderator
Never use a petroleum based lube on rubber. You should use only a silicone based lube. Vaseline is petroleum based.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
Cummins12V98
on the road
Posted: 05/22/22 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Tell that to my 6 year old toilet being used full time!
udidwht
Seattle
Posted: 05/22/22 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Rubber is petroleum based. As are many silicone items.
Scottiemom
Posted: 05/26/22 08:48am Link  |  Quote  |  Print  |  Notify Moderator
My manual says to use only silicone. I actually found a bottle of Toilet seal lubricant and conditioner made by Thetford and my commmode is a Thetford, so I figured that would be the best. It's working great on my 18 year old rig.
Dale
 > Easy toilet fix
