opnspaces
San Diego Ca
IF you are a member or have a friend who is I would buy the batteries at Costco. In San Diego Costco beats Autozone by at least $50 per battery.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
blt2ski
Kirkland, Wa
Cummins12V98 wrote: Never heard a bad word about Cooper's.
East Penn batteries sold under many names like Deka are US Made and TOP quality!!!
They also supply batteries to NAPA, West Marine among other house branded batteries. They've been a bit short supplied for a year or so due to Covid restrictions at the plant in Pennsylvania.
Marty
2014 Chevy 1500 Dual cab 4x4
Boomerweps
Hills of PA
Batteries have a build date clearly marked on them, often a punched hole type, for warranty purposes. Look closely, then decide.
IMHO, if you have any questionable battery symptoms, change it. Otherwise, wait. Most batteries, in average temperature conditions, last 5 years but many go 7 years, IME.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
dieseltruckdriver
Black Hills of SD
I have Cooper HT3s on my pickup and with 10k miles on them I am very happy. Much happier than the Goodyear Duratracs I previously had on it. They seem to be wearing much better.
I did use Falken Wild Peaks on my previous pickup and didn't mind them at all either.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
Batteries? Good call. A 4 year old Florida vehicle battery is on borrowed time, generally. Due to the heat. And your truck is sensitive to proper voltage.
I’ve been looking for replacements for my 2016. They’re getting a little slow and are original.
Generally OEM batteries (mopar, Delco, motorcraft) are good. Just saw Amazon has 850cca Delco AGM 94R batteries for $166. Seriously considering those.
Otherwise, Exide from Home Depot is a great value on the low end of the scale.
And if you want the best, get Odyssey AGM.
2017 Heartland Torque T29
agesilaus
North Florida
opnspaces wrote: IF you are a member or have a friend who is I would buy the batteries at Costco. In San Diego Costco beats Autozone by at least $50 per battery.
Costcos are mighty rare in Florida. One in Tampa about 2 hours away from here.
Thanks for all the replies. I went ahead and bought the Coopers at Discount tire. With their tire guarantee and taxes is was $1500+ for four, geez....
I'm impressed with the tires, very deep treads. Half an inch IIRC. I just could not find much info on the Falkens and they are even more expensive locally.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
Curly2001
Tucson, Arizona
Goodyear now owns Cooper Tire.
As far as Michelin LTX tires, I would find something else. I have run numerous sets of them on 3/4 ton trucks and only get 35K out of them, at the most. Discount usually gives me credit on other tires to purchase but no more Michelin for me. Will look at Cooper or BFG.
Curly
edited 05/22/22 06:48am by Curly2001 *
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
ACZL
UPstate,NY
The orig batts in my truck tho good still on juice, the gasses leaking out of the one was getting to be a PITA......not to mention being made in '16. So last year at a local battery place (not big brand/name place....just a local owned one) and bought 2 "2nds" for about 1/2 the price as "1sts" and have same wty. Got them last fall and no probs so far.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
jaycocamprs
Ringgold Georgia
blt2ski wrote:
Batteries as noted, are made by 3-5 manufactures here in NA. Choose poison by where you can get warrenty easy enough etc.
Marty
That great deal you got 2 years ago isn't, when your 700 miles away from home with a dead off brand battery.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
spoon059
Just north of D.C.
I am replacing my Ram's tires this week. I found a reasonable price on some Goodyear Wrangler All Terrain Adventure tires from my local Goodyear dealer. $260/tire plus installation, $75 instant rebate and up to $150 rebate if I use a Goodyear credit card. That brings my total down to $231/tire installed.
I am replacing some Nitto Dure Grapplers that have 5 years and approximately 50K miles on them. I still have tread left, but I think one of the belts in a tire broke, I have a huge bulge in the tire and a bad shake in the tire. Other than that, the Nittos were pretty good tires for me.
Bought my most recent batteries at Walmart, mainly because they were the only place with 2 batteries in stock! Original batteries lasted almost 7 years, so I was pretty happy with them.
2015 Ram CTD
2015 Jayco 29QBS
