RV.Net Open Roads Forum: leaving the stick and brick for the summer
 > leaving the stick and brick for the summer
cptqueeg
Idaho
Posted: 05/23/22 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
An often overlooked weak point is the condensate pan under the air handlers. They can get plugged and trip the float switch so air handler won't come on or overflow into the living space.
* This post was edited 05/23/22 07:34pm by cptqueeg *
ceasare
North Las Vegas
Posted: 05/25/22 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info. The only thing I don't know is if I can shut off the water. Have to find out where the drip irrigation system is hooked up. Can't shut that off.
Scottiemom
Posted: 05/26/22 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Another tip. If you have an ice maker, make sure you have a shut off when it's installed. We expect those little plastic tubes to last forever and . . . trust me. . . they DON'T! And they can leak a LOT of water in a short time.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
opnspaces
San Diego Ca
Posted: 05/26/22 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
I would shut off the water now and open a faucet in the sink to drain the pressure out of the pipe. Then turn off the faucet and go turn on the drip irrigation. It the drip is still going strong after a few minutes it's probably not controlled by that valve.
But I'll bet that your drip is in fact downstream (after) the valve and therefore will be a problem that you need to come up with a plan for.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
obgraham
TriCites WA
Posted: 05/26/22 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
As a snowbirder, we leave our place in Arizona (Mesa) for 6 months.
This is a big topic. Half of us turn everything off. They seem to manage.
I'm in the other half: a/c to 90. Leave reefer on, with all bath/kitchen stuff possible in it.
Humidity is a non-issue there. But yes, turn off the water main valve.
In all the places I've had, the irrigation is upstream of the house valve. On purpose.
