agesilaus
North Florida
Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
bobsallyh
Livingston, TX.
My Ram tire tools are the right-side passenger seat.
mike-uswest
Central Point, OR, USA
bobsallyh wrote: My Ram tire tools are the right-side passenger seat.
X-2
Mike
2019 Ram 2500 TCD, 4X4,
Arctic Fox 25Y 30'
fj12ryder
Platte City, MO
That's where mine should be, but aren't, since we bought the truck used. Oops. But a 1/2" socket extension reversed will work. And they sell just the tool on Ebay for a few bucks.
Howard and Peggy
"Don't Panic"
bucky
Raleigh metro
When you get the rod use it to make sure the hoist isn't bad. Lower it, oil the cable, and raise it back up to make sure that it works.
A lot of them have failed, we replaced them frequently as our shop was near the beach and they rusted sometimes solid.
You also need to inspect the tire for size and age, who knows what is under there. The tire valve should be pointed down so it's pressure can be checked occasionally. You don't need more than one flat at a time.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
spoon059
Just north of D.C.
Related question, does the spare have a TPMS sensor?
2015 Ram CTD
2015 Jayco 29QBS
Fire Instructor
Upstate (Albany) NY Area
spoon059 wrote: Related question, does the spare have a TPMS sensor?
No. I added an extra sensor to that when I put sensors on my trailer.
Fire Instructor
2022 Coachmen Leprechaun 319MB
Spare? Not any 4th gens I’ve seen. Ever.
But I just wish I could use my tpms. I had to delete the reading from the screen so as not to get the tire pressure warning to pop every time it’s started…stupid tpms limits. The tuner that unlocks the ECM for the real tunes will do that but not adjust the pressure thresholds.
I could spend the money to get an Autel scanner or something to lower the limits. But that’s a couple hundred bucks to overcome the issue. So I just deal with the tire light.
Thanks Ralph Nader!
2017 Heartland Torque T29
Fisherman
Angus, Ontario, Canada
agesilaus wrote: Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
Back to the question of needing a "key" to lower the spare, not on mine. One of the 4 sections of rod that get connected have a 5 sided open end that engages the stud on the crank mechanism.
agesilaus
North Florida
bucky wrote: When you get the rod use it to make sure the hoist isn't bad. Lower it, oil the cable, and raise it back up to make sure that it works.
Sounds like good advice
