spoon059
Just north of D.C.
Fire Instructor wrote: spoon059 wrote: Related question, does the spare have a TPMS sensor?
No. I added an extra sensor to that when I put sensors on my trailer.
Ok, thanks. I didn't remember and am getting my sensor batteries replaced when I get new tires this week. Appreciate it!
2015 Ram CTD
2015 Jayco 29QBS
fj12ryder
Platte City, MO
Fisherman wrote: agesilaus wrote: Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
Back to the question of needing a "key" to lower the spare, not on mine. One of the 4 sections of rod that get connected have a 5 sided open end that engages the stud on the crank mechanism. The one for the Ram is a square that is about 1/2".
Howard and Peggy
"Don't Panic"
bguy
The Rock
Oiling the cable does nothing. The cable pulley is sandwiched between 2 steel plates. The shaft sticks in the plates. This is where you need lube.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
LanceRKeys
Amarillo, TX
I had a cable break while towing my fifth wheel, got lucky and didn’t break anything on the trailer. Inspect carefully!
FishOnOne
The Great State of Texas
I had a oh chit moment when I recently tried to lower my spare tire, but couldn't get the long handle to engage the rotating gear box to lower my spare. Needless to say, I need to go back and figure this out before I need it on the side of the road with a flat tire.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
bucky
Raleigh metro
bguy wrote: Oiling the cable does nothing. The cable pulley is sandwiched between 2 steel plates. The shaft sticks in the plates. This is where you need lube.
Post that again when you see one looking like it's been in Salt Lake for 2 years. But your additional thought is a good one.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Cummins12V98
on the road
fj12ryder wrote: Fisherman wrote: agesilaus wrote: Not the jack, I may need the rod you use to lower the spare. With Ford you need a key like thingamajig you place on the end of the crank rod to engage the gear that lowers the tire. Does RAM need one. I need to search the track to see if these spare tire tools are in ir somewhere/ Where are those kept? Under the rear seat??
ZACTLY, I just lowered my Dad's spare to change out the rear shocks and it's square for sure on his 14 3500 RAM.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
agesilaus
North Florida
I got a Dorman spare tool kit, there was a 30 inch extension rod but the shipping time was too long. I'll crank the spare down today or tomorrow and lube everything. Thanks for the replies
Dorman tool
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
bguy
The Rock
bucky wrote: bguy wrote: Oiling the cable does nothing. The cable pulley is sandwiched between 2 steel plates. The shaft sticks in the plates. This is where you need lube.
Nice how you assumed I had no idea what rust is. You must be a joy to work with.
^Oh fer fcks sake, guy asked about getting a spare tire tool and you’re arguing about whether the sky is blue….I’d say grow up but you’re probably both eligible for AARP and maybe SSI.
2017 Heartland Torque T29
