cm11599ps
Long Island
I’ve got a 2013 Ram 1500 Big Horn with a tekonsha primus iq brake controller for out trailer that’s probably about 8,000 loaded. I was supposed to bring the trailer to a campground for my Dad to use but we just had a baby and I can’t get away long enough for a trip like that.
We have a family friend who is going on this trip too and he’s got a newer 1500 but no brake controller.
Is it an easy thing to just remove my brake controller from my truck, install it temporarily in his and then put it back in my truck once the trip is over? We had the rv dealer install the unit years ago so I’m not sure if it’s as simple as just unplugging it from mine and plugging it into his truck and then tidy up the slack wires.
Owens River area
You had a professional install your brake controller initially. That was a good idea then...and it is a good idea now.
bob213
Fresno, CA
Ram to GM more than likely requires a different wiring harness. Other than that (after setting it up) it should work.
cm11599ps
Long Island
It’s a 2013 ram 1500 to a newer ram 1500, probably like a 2019.
midnightsadie
ohio
call the builder of the maker.
jdc1
Rescue, Ca
bob213 wrote: Ram to GM more than likely requires a different wiring harness. Other than that (after setting it up) it should work.
Bob's correct. UHaul should have the correct harness.
dockmasterdave
florida
Look on e trailer, they'll have the harness cheaper than anyone and you'll have it in a couple days.
2014 F 150 ecoboost
2008 Chrysler Aspen
09 Amerilite 21 (modified)
2013 Bendron 14' enclosed cargo
2011 4x8 open cargo
bob213
Fresno, CA
Sorry..I saw 1500 and thought GM. It looks like Ram 2013 and 2019 use same wiring harness.
Lwiddis wrote: You had a professional install your brake controller initially. That was a good idea then...and it is a good idea now.
Yet people who aren't "professionals" do it all the time with no issue...
2017 Heartland Torque T29
cm11599ps wrote: I’ve got a 2013 Ram 1500 Big Horn with a tekonsha primus iq brake controller for out trailer that’s probably about 8,000 loaded. I was supposed to bring the trailer to a campground for my Dad to use but we just had a baby and I can’t get away long enough for a trip like that.
If the pigtail on your 2013 is the same as the one in the newer Ram, 99% chance it's plug n play. May still have to mount it in the truck so it can be tuned for level.
Other options, good enough friend to swap trucks with?
Wireless brake controllers are stupid easy, but will cost someone a couple hundo?
