RV.Net Open Roads Forum: Fifth-Wheels: Wobble Stoppers?
 > Wobble Stoppers?
BurbMan
Indianapolis, IN
Posted: 05/23/22 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Another trip in the books with the new rig! Had a few issues but no show stoppers!
One item on my fix-it list is stopping some of the bounce and wobble in the trailer. Current setup is all factory, landing gear in the front and crank-down stabilizers in the back. I also use a set of X-chocks between the wheels on both sides. Front-to-back movement seemed minimal, it felt like a lot of movement was lateral. I've seen the braces that form an X between the landing gear, also a tripod device that goes under the king pin, etc. but don't want to waste money on junk.
I wanted to get opinions from the experienced 5er guys on what's the best bang for my buck in stopping the wobble?
* This post was edited 05/23/22 06:06pm by BurbMan *
fj12ryder
Platte City, MO
Posted: 05/23/22 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Dump the tripod and invest in some JT Strongarm stabilizers. That type of control will get rid of most of the wobble. There is always going to be a little bit, unless you lift your trailer tires off the ground with solid mounts.
Howard and Peggy
"Don't Panic"
frankwp
Calgary, AB, Canada
Posted: 05/23/22 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, toss the tripod. If you install a set of strong arms, you can go to regular wheel chocks because the X-chocks won't be adding any stabilities at all. Depending on the length, you may want to even add crank down stabilizers next to the axles.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
larry barnhart
wenatchee. wa usa
Posted: 05/23/22 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
We did what you said on our alpenlite because the wife sat above the wheels and did needle work so a set of scissors jacks in front of the wheels fixed the issue but later added the Jt's for sitting the 6 months in Az. Nice to have the stable fifth when the wind blows hard.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Lantley
Ellicott City, Maryland
Posted: 05/23/22 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for JT Strongarm stabilizers
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
BurbMan
Indianapolis, IN
Posted: 05/23/22 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys. Need new landing gear pins so am gathering my order together. I just realized my typo in my original post, I don't have a tripod or anything right now, I meant to say I've seen them around a lot.
msmith1.wa
Tacoma, WA
Posted: 05/23/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Another vote for stabilizer jacks near the axles.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
JIMNLIN
Oklahoma
Posted: 05/23/22 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
JTs or a similar product work great for lateral and up and down movement.
I've used a aluminum bipod pin stabilize since our first 5th wheel trailer in 1990. Didn't take but one trip till the brain kicked in and figured out it can only stop lateral movement at the front of the trailer.
Bought a BAL telescoping stabilizer for the rear of the trailer which stops lateral moves back there ....and adjustable chocks between the tires that eliminated fore and aft movement for a rock solid trailer.
I've used this method on three different 5th wheel trailers.
ford truck guy
Pennsylvania
Posted: 05/24/22 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Back before we had the 6 point system, we did the following . .
Got a tripod... gave the tripod away after 1 use... added a pair of telescoping jacks at the axle, added JT's, added a pair of jacks at the rear bumper as there was a decent overhang.. cut some 6x8x8 wood blocks to allow the jacks to be a bit more stable, all movement was pretty much eliminated . . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ACZL
UPstate,NY
Posted: 05/24/22 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for ditching the Trip-pod and getting the JT's. Also, re-tighten the X-chocks after tires cool down and if possible, add more blocks of wood under any points of contact the front legs/rear stabs have w/ the ground to shorten the extension of said components. But all in all, the JT's will be your best friend.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
 > Wobble Stoppers?
