RV.Net Open Roads Forum: Tech Issues: SiO2 Charging Profile
 > SiO2 Charging Profile
BFL13
Victoria, BC
Posted: 05/23/22 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
56.5 constant amps in Bulk is 28% charging rate--expect lower rate to run to a higher SOC before tapering but take longer over all.
">][image]
Here is the old ugly graph again showing 55 amps on a pair of FLAs rated at 220 but might have been more like 200 if they used the 1 amp instead of the 20 hr rate--don't know now. Doesn't make a lot of diff here though.
">][image]
You can see the times to do a 50-90 are longer with the FLAs because of earlier tapering. Took an hour to do the 80-90 vs 1/2to do the 80-90 with the SiO2
There is some inaccuracy due to the monitor not showing any heat loss but that seems to be not much of a factor. Anyway there it is.
* This post was edited 05/23/22 03:34pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Owens River area
Posted: 05/23/22 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting observations. TY for posting.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
BFL13
Victoria, BC
Posted: 05/23/22 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Whoever replied at 1521, it's not showing on mine yet. Apparently that means you are in Admin's bad books! [emoticon]
pianotuna
Regina, SK, Canada
Posted: 05/23/22 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Ty BFL13,
Useful information.
I'd be tempted to stop at 80% myself.
Regards, Don
3 tons
NV.
Posted: 05/23/22 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
X2!! Thanks BFL for the good information!
3 tons
BFL13
Victoria, BC
Posted: 05/23/22 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Ty BFL13,
Useful information.
Yes 40 - 80s is 40% too and save gen time
Note this is not much use with solar No constant amps and amps taper from noon as sun lowers regardless of battery SOC
StirCrazy
Kamloops, BC, Canada
Posted: 05/24/22 06:36am Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
pianotuna wrote:
Ty BFL13,
Useful information.
Ok so I am not sure if this applies as much to SiO2, maybe some one can tell me as there is nothing showing up on a google search, but I see a lot of people only charging normal batteries to 80% all the time are you not worried about sulfication.
if you do this continuously, or even just store the battery with a partial charge, it can cause sulfating which reduces the capacity of acid batteries.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
BFL13
Victoria, BC
Posted: 05/24/22 07:56am Link  |  Quote  |  Print  |  Notify Moderator
With FLAs doing successive incomplete recharges in a row leads to Progressive Capacity Loss. We talked about this on here about ten years ago. You must do a "recovery" to Full every so often or your capacity gets so low you can't get through the next night. Depends on the whole scenario how many days you can do it.
Solar solved that by doing shallow instead of deep cycles and by getting close to or even to Full often when the sun is out. You still have to get to Full every so often and do an overcharge per battery guidelines.
Here is a plot showing PCL with five successive 50-90s I did about ten years ago.
">][image]
Posted: 05/24/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Wudn't me!
2017 Heartland Torque T29
time2roll
Posted: 05/24/22 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Seems fine although not exactly impressed. Seems more limited than what some have previously expressed.
Good to know the SiO2 is working for you.
675w Solar pictures back up
