beav1017
mart, tx
I need someone to work on my auto park brake on a 1995 bounder p-30 chassis near Waco, tx. the light is on and it does not engage. please contact if can help. thanks
RLS7201
If the mechanic you find is not fully informed about the auto-park system, share the links below. All the details needed to trouble shoot your auto-park is at those 2 web sites.
Oemy's
Old Used Bear's auto park info.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
beav1017
mart, tx
thanks
Gjac
Milford, CT
Check the green pressure switch they often leak and require replacement. If you take off the access plate you can see it look for transmission fluid on the switch. Also check the fluid level.
