RV.Net Open Roads Forum: Travel Trailers: Best 30 to 50a adaptor?
 > Best 30 to 50a adaptor?
DinTulsa
Tulsa
Posted: 05/23/22 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Switched lakes this year and the campground that a lot of friends are staying at this summer is 30a only. I normally try to stay at 50a spots, but there are a few weeks that it’s not possible. I have had an adaptor that I have used over the last 6 years on rare occasion, but it can get warm to the touch at times. Is there an adaptor that can run a WH/15k aC without getting warm to the touch? At one campground I actually set a fan at the pedestal to blow on the adaptor which kept it cool.
Just looking for a high quality 30-50 adaptor.
CA Traveler
The Western States
Posted: 05/23/22 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Clean the 50A plug lugs, bright shiney clean. Buy a pigtail type adapter, not a hockey puck type. 30A is plenty to run a 15K AC but don't exceed 80%/24A, probably some minor adapter heat. This assumes the pedestal is in good shape which is always questionable for 30A plugs that are often very used and abused.
2014 Grand Cherokee Overland
Bob
BB_TX
McKinney, Texas
Posted: 05/23/22 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Did it get warm at the 30 amp end or the 50 amp end? Assuming it is a dogbone adapter.
pianotuna
Regina, SK, Canada
Posted: 05/23/22 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Make your own dog bone adapter with larger wire. Keep the tines bright.
Regards, Don
DinTulsa
Tulsa
Posted: 05/25/22 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
