RV.Net Open Roads Forum: Truck Campers: 3.42 gears for TC
 > 3.42 gears for TC
Page of 5
TxGearhead
Posted: 05/26/22 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would seriously consider a gasser.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
jimh406
Western MT
Posted: 05/26/22 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
I agree unless range is a consideration.
ssthrd
Vancouver Island
Posted: 05/26/22 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
LL8 wrote:
Thanks for all the replies folks. Learned a lot
Stay tuned LL8. I suspect that this could be another hundred or so post thread.
2014 Keystone Laredo 292RL
2011 Palomino Maverick 800M
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
trail-explorer
NM
Posted: 06/02/22 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Don't overthink it.
It's a Duramax. It will be fine. If it wasn't fine, then the factory wouldn't offer only one gear ratio.
Duramax trucks used to have 3.73 as the only gearing, but that may have changed when the 10 speed was introduced.
Posted: 06/02/22 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Naw, I doubt it. He's so over trucked with a new Dmax, both on the power and payload that not even the strictest of weight cops will likely try to argue the point. (Although I've been wrong about that before on here, lol)
I just can't figure out how a guy who has owned 2 other top of the line diesel trucks, both with small lightweight campers on them would be asking about whether a new truck that has even more power and every bit as capable from a payload standpoint would be an issue for an equally small camper....
2017 Heartland Torque T29
mkirsch
Rochester, NY
Posted: 06/03/22 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Oh that's easy. He's stuck in the 1970's, the days of, "Ya can't tow nothin' without 4.10 gears."
3 tons
NV.
Posted: 06/04/22 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
Huh?? Time now to recognize the ‘new reality’ - Nowadays (21st century…) with the final three gears ‘as overdrives’ how is it that a 4:10 any kind of obstacle!!
3 tons - with a DRW 4:10, 6 speed, two final gears are both overdrives, purrs at 70 mph
Posted: 06/05/22 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
And with twice as deep of first gear as old transmissions and 7 gears from low to direct, the bottom end of the gearing will do what usta take 4.10s.
So, huh?
(Not that you’re wrong, new crop of pickups are putting down so much power and with 10speed transmissions they can comfortably pull tall gears with pretty big loads or really pull houses off their foundations with short gears and run 90mph+ bobtail at comfortable rpm’s. )
valhalla360
No paticular place.
Posted: 06/06/22 05:34am Link  |  Quote  |  Print  |  Notify Moderator
There's nothing magical about overdrive. It's just another gear ratio.
With moderate towing or city driving, not much difference. It will pick the gears that match the RPM the truck decides the engine should run at. Very rarely will it get into top gear and it won't really need 1st gear hardly at all.
It's at the far ends of the operational regime where it makes a difference:
- When towing really heavy in mountainous conditions, you might exceed the tow ratings with the 3.42. Then the 4.10 might get you the maximum towing capability for the truck..
- When not towing and cruising at high speed on the freeway, the 4.10 may get the RPM higher than ideal even in top gear. The 3.42 will allow the engine to stay in the optimal RPM range.
Given the tremendous towing capability of modern trucks, the 2nd situation is likely to be beneficial far more often.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mkirsch
Rochester, NY
Posted: 06/06/22 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Three words: Fuel economy standards.
You're still >2000RPMs at 70MPH in OD with your 4.10s. I know I'm at 2500RPM with mine, but it's a gasser. With 800HP and 1000TQ or whatever these latest diesels are pushing out, you should be able to run 70 empty loping along at 1200RPM.
Page of 5
 > 3.42 gears for TC
