RV.Net Open Roads Forum: Unknown or erroneous title on single axle fifth wheel
 > Unknown or erroneous title on single axle fifth wheel
Page of 6
Posted: 05/29/22 07:17am Link  |  Quote  |  Print  |  Notify Moderator
CohoSalmon wrote:
Thanks everyone. When I have internet I will post a picture. [image]
Man, that's awesome. Nice Find
2013 KZ Durango 2857
Carl n Susan
Carmichael, CA
Posted: 05/29/22 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I camped in 2006 with some friends of friends and one couple had a very similar 5th wheel. Very small compared to today's standards. They had completely redone the inside and it was immaculate. I remember the external frame for the jacks and hitch as it was the first time I had seen one like that. I hoped I had a picture but I was unable to find one.
BurbMan
Indianapolis, IN
Posted: 06/06/22 07:29am Link  |  Quote  |  Print  |  Notify Moderator
NO WAY that's a truck camper...if you put that in a truck bed, the camper door would never open! The external frame that supports the cabover and pinbox is an unusual design , but NO WAY is that a "homemade" fifth wheel, it was built as a 5er and it came from the factory like that.
valhalla360
No paticular place.
Posted: 06/06/22 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I'm a little confused:
- Is the DMV refusing to title it?
- Is it curiosity regarding the original manufacturer?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CohoSalmon
Washington
Posted: 06/10/22 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
The DMV told me it's a homebuilt. I had a title from a deceased owner. It's date of"home building" was 1990. DMV had me track down the widow. I got my title as a homebuilt. No one challenging me yet...... however....truth is... it's factory built in the mid 70's. The mfgr serial number went missing somehow...it might be stolen .. but I got it when a renter moved out and abandoned it.
Wadcutter
IL
Posted: 06/11/22 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I know that IL DMV will often re-label older trailers as home built instead of making the effort of finding an original title. Seem them do it on newer trailers too. Some states do not require a license/title for small trailers so a person can buy one in those states and lose the title over the years because they don't have to license it. Then they sell it to someone from a different state that requires a title. Instead of the 2nd state researching for a title or requiring the new purchaser to get a title which may be near impossible the 2nd state DMV will just do a home built title.
Like your 5er it's obviously not a home built but given its age I can see where a previous owner might have lost the title, if they ever had one.
Camped in every state
Thermoguy
Graham, WA
Posted: 06/11/22 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Finally a 1/2 ton towable 5th Wheel!!
[emoticon]
CohoSalmon
Washington
Posted: 06/14/22 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
As I said in the beginning, I've not been an RVer in the past.....however, I do need living quarters on ajob site. I built a metal roof to keep the rain out of this 45 year old trailer. I've come to like it. Yes, the size is very attractive for one person. I can see the simplicity of towing and use for one person. As I replace those incandescent lights with LED I'm also trying to get the water system working. I hooked up a water hose, 72 lb pressure, and promptly blew something out. I turned on the 12 volt pump and it works fine except there's a leak somewhere. I'm totally intimidated by what seems to me a very complex system of hot water tank, holding tank, fresh water tank, external source, and I don't know what else. Is there a site for "RV water systems made simple"?
IAMICHABOD
Sunny So Cal
Posted: 06/14/22 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Well if you have access to the internet Youtube is a great resource
for all of this.
This may well get you started
It has helped me out many times.
Good luck
Long ago I had a friend that had one like yours,I had never seen a fifth wheel that small,he pulled it with his Ford Ranger.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
dougrainer
Carrolton, Texas
Posted: 06/15/22 06:26am Link  |  Quote  |  Print  |  Notify Moderator
https://camperguide.org/rv-plumbing-diagram/
Page of 6
