canman4800
Southern Wisconsin
I have a 2018 f-150 with push button start. can it be towed wheels down and what would have to be done to allow it?
"the worst day at the campgrounds is still better than the best day at work"
mleekamp
Washington, IL
Start with the owners manual. Look up the 2018 RV Flat Tow/Dinghy guide here via Camping world, I think links at top of page.
I looked into towing our 2016 F150 flat down and it was doable. Went with a Jeep, now wife tags along behind as we downsized expenses so oldest could go to college.
I'm sure others here will have experience with your application.
BurbMan
Indianapolis, IN
You can find the owner's manual on the Ford website here. Page 311-312 says that if the vehicle is 2WD it cannot be towed with ANY wheels on the ground, ever. If the truck is 4WD, there is a procedure on p312 that tells you how to put the transfer case in neutral and prepare for 4-down towing.
Cambria, California area
Suggest you follow Ford instructions and limitations to the letter...and save a repair bill.
JoeH
Apollo Beach,FL
As others said, if it's a 4x4, you can tow 4 down. I've been towing my 2015 since new with no issues.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
opnspaces
San Diego Ca
BurbMan wrote: You can find the owner's manual on the Ford website here. Page 311-312 says that if the vehicle is 2WD it cannot be towed with ANY wheels on the ground, ever.
I'm not about to argue with the ford engineer that wrote that manual. But it would have been nice if they had explained how the vehicle can be damaged by towing with the front wheels on the ground on a 2wd truck.
Two-wheel Drive Vehicles
You cannot tow a two-wheel drive vehicle
with any wheels on the ground as vehicle
or transmission damage may occur. You
must tow your vehicle with all four wheels
off the ground, such as when using a
car-hauling trailer.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Mike134
Elgin, IL
opnspaces wrote: BurbMan wrote: You can find the owner's manual on the Ford website here. Page 311-312 says that if the vehicle is 2WD it cannot be towed with ANY wheels on the ground, ever.
Because a two wheel drive truck the transmission will have some gears and clutches turning but without lubricant being pumped around/through them. That's why there will be transmission damage.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BurbMan
Indianapolis, IN
More likely because a 2WD truck is RWD, so to use a dolly under the rear wheels would mean towibg backwards which doesnt sound like a good idea.
